Pitch the pistons?, 94mm vs. 96mm |
tumamilhem |
Jan 9 2013, 02:48 PM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
I have a 1974 2.0 engine. I understand replacing the 94mm stock pistons to 96mm pistons will add an additional 80 cc or so to 2056 cc. Is this correct? And if so, would I need to make any changes to the mechanics to make the system run properly, fuel injection for example? Or will everything run efficiently as is if the larger pistons are installed? Looking to increase power while keeping the engine.
Thanks in advance for your input! |
rhodyguy |
Jan 9 2013, 03:12 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,198 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
as above. it's about everything else except the the displacement increase. not an install and go deal. start adding 0s.
Lo-Fi Version | Time is now: 6th January 2025 - 05:30 PM |
