CG-914 |
Member ![]() ![]() Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California ![]() |
Had my engine for machine work at Rimco,
and after they forget to send parts back I know finally after ... (IMG:style_emoticons/default/dry.gif) I have my dowel pins from the flywheel back I send in case they needed them for the balancing. I am not sure if they send me the right pins back so here are the pics with measurements... ![]() ![]() ![]() |
CG-914 |
Does somebody have a set laying arround he or she can compare the size?
20 mm x 6 mm (IMG:style_emoticons/default/icon_bump.gif) |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,183 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Does somebody have a set laying arround he or she can compare the size? 20 mm x 6 mm (IMG:style_emoticons/default/icon_bump.gif) Yeah, I have three out, waiting to go back in. I will try to remember tonight. Right off the bat though, the ones you have look spot on. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:23 PM |
