bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
With the help of my lovely wife, I have made the air pressure measurements on my 914 at speed. The reference point was the ashtray in the dash. The ends of both hoses were buried in the center of 2" blocks of open cell foam to prevent air movement from affecting the pressure readings. I realize the reference point is not going to be at exactly zero, but as a reference it will show pressure diffrences between different parts of the car. The windows were rolled up, and the targa top was on. Here are the numbers, in kilopascals:
at 45 MPH front center of front bumper: 0.21 middle top of front trunk lid: 0.03 inside front of front wheel well: 0.00 middle top of roll bar: -0.03 middle of rear window: -0.03 inside engine compartment (coasting at idle): -0.01 inside rear wheel well: 0.02 at 65 MPH front center of front bumper: 0.44 middle top of front trunk lid: 0.02 inside front of front wheel well: 0.01 middle top of roll bar: -0.05 middle of rear window: -0.04 inside engine compartment (coasting at idle): -0.03 inside rear wheel well: 0.03 After our last measurement, we rolled down the driver's side window and drove at 45 MPH to see what difference that made on the reference point. The rear wheel well measurement went up from 0.02 to 0.07, which means that at 45 MPH the pressure at the ashtray is 0.05 kPa lower with the driver's side window down. Whelp, there's my little numerical contribution to the 914 community. --Royce |
bondo |
I'm sure of the units, but the reference point is probably not at atmospheric pressure. The numbers can't tell you what pressure is at a certain place, only the difference in pressure between measured points.
As for air being sucked out of the engine bay, that can't be known without measuring the pressure at the underside of the car, which I didn't do. I would think the pressure must be lower down there or the porsche designers would have made the cooling fan suck air from underneath and blow it out the top. The engine compartment measurement was taken next to the air cleaner, on the driver's side. There was no rain tray. One of the possible explanations for the front wheel well measurement being higher than expected is I have no front valence. (it got caught on a curb and pretzelized a couple months ago) Sorry my 914 is such a beater (IMG:style_emoticons/default/smile.gif) I would imagine that you could lower those numbers even further with a an LE spoiler or something like that. --Royce |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:13 PM |
