My 3.3L Subie Conversion Thread, Got me some 914rubber stuff |
Chris H. |
Dec 27 2012, 11:02 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Finally starting the thread. First, I never would have done this if it weren't for several of you helping me out, especially Ian at:
Cold Water Conversions Ian tolerated dozens of questions from me as I decided which way to go. Thanks again! Here is the candidate (or victim, depending on what side of the fence you are on): A 1975 1.8L with California Emissions...I've had it for almost 11 years. During that time I have logged about 2800 miles on it. I decided to swap it out for a modern drive train so my daughter could drive it so I started looking for a 2.2L Subie and a 2WD auto trans. This setup CAN be made to work with a custom hanger, but it's not a very exciting trans. Think early '90's Camry or Corolla acceleration. I'm sure it could be re-geared but an Audi trans would probably be a much better option. Then I found and SVX for cheap and changed directions entirely. Looks like my kid will be learning to drive a 5 speed Subie! So far I have: Strong running SVX engine 2006 WRX trans purchased from NASIOC If you don't feel like chasing this stuff down Ian will source it for you. Next up I'll post the highlights of the SVX strip-down and note some of the pitfalls, valuable parts, and stuff to be careful not to break! Any feedback, comments, questions, concerns are welcome. I want to do it right. |
Chris H. |
Jan 23 2013, 06:44 AM
So the angle of the intake has gotten my attention. Bob and I spoke of flipping it which can be done but might require rearranging of the alternator.
When you look at it from the top it looks like it will clear since the angle is so steep.... But under the intake snorkels is this little guy which will probably make it harder. I suppose a spacer could work...we'll see. Otherwise the alternator could be moved... Attached image(s) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:06 AM |
