JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Okay so as you saw in the other thread I just bought 2000 z28 with an LS1 in it. I got a great deal on it & just bought the whole car. Since it is a driving car I am going ot get everything else ready to go before I pull it. Question is what things should I consider doing to my car? I allready have a 5-lug converison done with 944 turbo Brembo's up front.
My chassis is solid but should I consider adding a cage? Is it needed? What transmission should I use? I know the 901 can handle it with 1st bypassed. I'd really like to do a Boxters S 6 speed transmission. If I have to spend money getting an adapter plate. Why not upgrade my tranny also? For an engine mount did anyone make a cradle? Or did you just do a bar setup like stock but setup for the LS1 motor mounts? I'd like to keep the a/c. What would I need to make that work in my 914? While everyone is welcome to put there 2cents in. I'd really like to hear from all the guys who have done the LS1 conversion. Do you run the stock water pump or something else? I added a pic of my car as it currently sits. I will be painting it also (or Jerry Mahoney will) at some point. Leaning towards Phoenix red Attached thumbnail(s) ![]() |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Are there any other pics of LS engines installed? Is there anyway to avoid cutting into the trunk for the intake system?
pjhaun |
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None ![]() |
Are there any other pics of LS engines installed? Is there anyway to avoid cutting into the trunk for the intake system? If I'm not mistaken, I think that Edlebrock has a intake manifold that fits the LS1. The only thing you would have to due is get a throttle body that would fit , mount fuel injectors and fuel rails. Phillip J. Haun Oak Harbor, Wa. |
Lo-Fi Version | Time is now: 27th June 2024 - 08:17 AM |
