JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,308 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Okay so as you saw in the other thread I just bought 2000 z28 with an LS1 in it. I got a great deal on it & just bought the whole car. Since it is a driving car I am going ot get everything else ready to go before I pull it. Question is what things should I consider doing to my car? I allready have a 5-lug converison done with 944 turbo Brembo's up front.
My chassis is solid but should I consider adding a cage? Is it needed? What transmission should I use? I know the 901 can handle it with 1st bypassed. I'd really like to do a Boxters S 6 speed transmission. If I have to spend money getting an adapter plate. Why not upgrade my tranny also? For an engine mount did anyone make a cradle? Or did you just do a bar setup like stock but setup for the LS1 motor mounts? I'd like to keep the a/c. What would I need to make that work in my 914? While everyone is welcome to put there 2cents in. I'd really like to hear from all the guys who have done the LS1 conversion. Do you run the stock water pump or something else? I added a pic of my car as it currently sits. I will be painting it also (or Jerry Mahoney will) at some point. Leaning towards Phoenix red Attached thumbnail(s) ![]() |
bulitt |
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States ![]() |
Guess its a personal decision. The LS1 for example in 350hp trim will get over 30mpg with the stock injection. Probably lose some of that with the carb in place. Then if you are going to run a carb, why not just put a SBC in? Used to be the LS engines were cheap but now everyone wants one so the cost of a SBC with aluminum heads is equivalent, and the weight diff between a LS and alum head/intake SBC is close.
I paid 1000$ for my 327 .060 over 330hp, brand new rebuild, with the manifold. Holley avenger for 300$, Headers and pertronix another 300$ The LS is quite the engine, hp easy to add, crazy fuel mileage, no fuel smell out the tailpipe. I would just cut the trunk and save the piece. |
speed metal army |
Waiting for the rain to stop... ![]() ![]() ![]() Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada ![]() |
Guess its a personal decision. The LS1 for example in 350hp trim will get over 30mpg with the stock injection. Probably lose some of that with the carb in place. Then if you are going to run a carb, why not just put a SBC in? Used to be the LS engines were cheap but now everyone wants one so the cost of a SBC with aluminum heads is equivalent, and the weight diff between a LS and alum head/intake SBC is close. I paid 1000$ for my 327 .060 over 330hp, brand new rebuild, with the manifold. Holley avenger for 300$, Headers and pertronix another 300$ The LS is quite the engine, hp easy to add, crazy fuel mileage, no fuel smell out the tailpipe. I would just cut the trunk and save the piece. The LS is a better choice than the SBC in a few ways..No cutting for the dist,lighter, more HP in stock form etc.They run cleaner too like you said.The carb was a fun way to go,and it can be replaced any time with FI.My motor cost me $750,complete,then another 600 or so for ignition,carb,manifold etc.That being said,I know of a whack of guys with 383's and 400's that cant give em away.Everyone is going LS. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:25 AM |
