JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Okay so as you saw in the other thread I just bought 2000 z28 with an LS1 in it. I got a great deal on it & just bought the whole car. Since it is a driving car I am going ot get everything else ready to go before I pull it. Question is what things should I consider doing to my car? I allready have a 5-lug converison done with 944 turbo Brembo's up front.
My chassis is solid but should I consider adding a cage? Is it needed? What transmission should I use? I know the 901 can handle it with 1st bypassed. I'd really like to do a Boxters S 6 speed transmission. If I have to spend money getting an adapter plate. Why not upgrade my tranny also? For an engine mount did anyone make a cradle? Or did you just do a bar setup like stock but setup for the LS1 motor mounts? I'd like to keep the a/c. What would I need to make that work in my 914? While everyone is welcome to put there 2cents in. I'd really like to hear from all the guys who have done the LS1 conversion. Do you run the stock water pump or something else? I added a pic of my car as it currently sits. I will be painting it also (or Jerry Mahoney will) at some point. Leaning towards Phoenix red Attached thumbnail(s) ![]() |
pjhaun |
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None ![]() |
How are you guys activating your electric water pump?
Thank You!!!! Phillip J. Haun Oak Harbor, Wa. |
Cracker |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States ![]() ![]() |
I had mine wired off the relay/fuse block of the engine wiring harness (powered "on" switched ignition). I then installed an over-ride switch so I could run it after the engine was turned off...one of the benefits of electric pumps is you can quickly lower the temps (w/o engine power).
How are you guys activating your electric water pump? Thank You!!!! Phillip J. Haun Oak Harbor, Wa. |
Lo-Fi Version | Time is now: 27th June 2024 - 08:39 AM |
