adiokyro |
Oakland, Ca ![]() ![]() Group: Members Posts: 74 Joined: 27-January 13 From: United States Member No.: 15,437 Region Association: Northern California ![]() |
Hi--
I searched around to see if I could find any info on this and cannot---perhaps because maybe its not even called a fan housing? At any rate I have purchased a straight low rust 1971 914 with a spare 2.0 and I intend to have a wack at rebuilding the engine myself. I have all the fi off, engine tin, the alternator, distributer etc BUT I cant seem to get the cover or case for the fan (fan housing?) off. Ive taken off all the slot screws that I can find, and the alternator and I can lightly pull it apart in areas but its still attached. I ordered the rebuild book but its not here yet----and trick to removing the flippin fan housing? thanks!!! (IMG:style_emoticons/default/smile.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Hi-- I searched around to see if I could find any info on this and cannot---perhaps because maybe its not even called a fan housing? At any rate I have purchased a straight low rust 1971 914 with a spare 2.0 and I intend to have a wack at rebuilding the engine myself. I have all the fi off, engine tin, the alternator, distributer etc BUT I cant seem to get the cover or case for the fan (fan housing?) off. Ive taken off all the slot screws that I can find, and the alternator and I can lightly pull it apart in areas but its still attached. I ordered the rebuild book but its not here yet----and trick to removing the flippin fan housing? thanks!!! (IMG:style_emoticons/default/smile.gif) Remove the fan. Remove the 4 8mm nuts and washers behind it. Make sure the thermostat wire is disconnected from the connection on the flapper shaft. Pull the shroud off. Done. Have an adult beverage and rest on your laurels while patting yourself on the back. The Cap'n |
Lo-Fi Version | Time is now: 25th June 2024 - 10:33 PM |
