adiokyro |
Oakland, Ca ![]() ![]() Group: Members Posts: 74 Joined: 27-January 13 From: United States Member No.: 15,437 Region Association: Northern California ![]() |
Hi--
I searched around to see if I could find any info on this and cannot---perhaps because maybe its not even called a fan housing? At any rate I have purchased a straight low rust 1971 914 with a spare 2.0 and I intend to have a wack at rebuilding the engine myself. I have all the fi off, engine tin, the alternator, distributer etc BUT I cant seem to get the cover or case for the fan (fan housing?) off. Ive taken off all the slot screws that I can find, and the alternator and I can lightly pull it apart in areas but its still attached. I ordered the rebuild book but its not here yet----and trick to removing the flippin fan housing? thanks!!! (IMG:style_emoticons/default/smile.gif) |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
As far as I remember, there are only the 4 studs behind the fan and a bolt through the oil cooler bracket (passenger side) holding the fan housing on (shown in red) (IMG:style_emoticons/default/confused24.gif)
Try tapping it with a rubber mallet ... ![]() |
adiokyro |
As far as I remember, there are only the 4 studs behind the fan and a bolt through the oil cooler bracket (passenger side) holding the fan housing on (shown in red) (IMG:style_emoticons/default/confused24.gif) Try tapping it with a rubber mallet ... ![]() Oh I see, I have all the fan bolts loosened but fan still stuck, pry it out? |
Lo-Fi Version | Time is now: 25th June 2024 - 10:31 PM |
