Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,997 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I've wanted to convert my 914 taillights to LED for a while but never got around to it.
Finally I started working on the design of the taillights. This will be a single custom PCB for each side and will have all the LEDs and control circuits on it. One PCB will be used for both sides. The plan is to remove the existing plastic reflector and bulb assembly and mount a custom board in its place. With proper standoffs, I should be able to mount the board using the same 2 screw holes that secure the reflector. I'm trying to decide now how many LEDs to use for each purpose. Right now, I have 8 LEDs for the backup lights, 20 LEDs for the running/Brake lights, 24 LEDs for the turnsignals, and 4 LEDs for the side marker. I've been observing modern cars with LED taillights and some use a few LEDs (like 8) and some a lot (+20). I would like your opinions on how many LEDs you think would be good to use. On the board below, the LEDs are spaced about 0.7 inches apart. These will be medium brightness white LEDs. (I'll let the lenses provide the color). The first cut at the board is shown below for the driver's side. The side marker LEDs will be right angle LEDs pointing out the side of the board. They can be seen on the extreme left side of the board. If these work out, I could manufacture them for World members. One thing though, they won't be cheap. The LEDs are about $0.50 through Digikey and there are more than 55 LEDs on each right now. Plus there's 2 dc-dc converters for providing constant current for the tail/brake and turnsignal LEDs. Cheers (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) ![]() |
tscrihfield |
Drive Fast and Take Chances ![]() ![]() ![]() Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None ![]() ![]() |
Spoke let me know if you need any help on this. I deal with these everyday and I have very good connections with all of my Board suppliers. If the order is small enough, I can probably have these boards ran for free or nearly free. I buy close to 5 million in bare boards each year and have good reputations with PCB houses. I would love to help you get the cost down as I am interested in these as well.
I can probably get the LEDs at cost as well. I can run them through a personal PO to Avnet, Digikey or TTI. Whichever has a better deal... Thomas |
Spoke |
Spoke let me know if you need any help on this. I deal with these everyday and I have very good connections with all of my Board suppliers. If the order is small enough, I can probably have these boards ran for free or nearly free. I buy close to 5 million in bare boards each year and have good reputations with PCB houses. I would love to help you get the cost down as I am interested in these as well. I can probably get the LEDs at cost as well. I can run them through a personal PO to Avnet, Digikey or TTI. Whichever has a better deal... Thomas Thanks Thomas, I'll keep that in mind. The main issue right now is to find an LED which is efficient enough to give the brightness I'm looking for and somewhat affordable. Any suggestions of an LED would be appreciated. The first one I tried didn't give the output I was looking for. Here's the info at Digikey: Cree LED I found an OSRAM LED with twice as much output. I'll get some samples of this one and give it a try. OSRAM LED |
Lo-Fi Version | Time is now: 30th June 2024 - 07:39 PM |
