wiring short |
wiring short |
jdlmodelt |
Jan 28 2013, 07:39 AM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
So, I've been finalizing wiring on my recently acquired 914. I had all the wiring except the license plate lights hooked up. I got my license plates last week and was checking the lighting last night. I could smell something and I saw a whisp of smoke coming from the three wires that go to the engine compartment light. I immediately pulled the battery positive cable off. I could feel the heat on the cable shield going to the engine compartment light. I could feel some minor heat going back through the bundle of wiring to the rear tail lights and ultimately to the license plate lights. Is there a particular place in this that others have experience this wiring short? I guess I need to remove the protective sheathing from the bundle to make sure wires didn't get melted together along the heat path. I was disappointed to see that the fuse feeding those wires did not blow, It just started melting the plastic fuse body? It was an 8 Amp fuse and I'll have to look at my printout to see what position it was in. Approximately a middle fuse in the fuse block.
Any ideas? thanks, James |
JeffBowlsby |
Jan 28 2013, 10:08 AM
914 Wiring Harnesses Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Did you get the license plate lights hooked up correctly? If you reversed them its a direct short to ground.
Attached thumbnail(s) |
jdlmodelt |
Jan 29 2013, 07:39 AM
Did you get the license plate lights hooked up correctly? If you reversed them its a direct short to ground. Yep! That's exactly what happened. Silly me to think that the license plate lights were isolated from ground! It didn't damage any other wires in the harness that I could determine and license plate light now works. Well, one of them. the other one is burned out. I'm having problems determining why the fuel tank sending unit won't work. j |
Lo-Fi Version | Time is now: 26th June 2024 - 12:40 AM |
