> AAR Picture needed
442nd914s
post Jan 30 2013, 02:17 PM
Can someone post a picture of a stock 2.0 Lt Auxiliary Air Regulator (AAR). No aftermarket. Installed in the engine prefered, but not necessary.
Greatly apprecitate. Thanks
442nd914s
post Jan 31 2013, 02:20 PM
Thanks for the pictures!!! That's exactly what I needed.
On more thing.
If someone can educate me on how this AAR ties in/works. The way I understand it is:
This is an air bypass till it warms up.
Upon start up the valve is open allowing air to flow thru normally. Power (12vdc) is applied to the built in heating element to slowly close up the valve. At which then it air flow thru this AAR is cut off and throttle body controls the air flow and idle. Is this right?
I'm just trying to trouble shoot my high idle. I've timed it to 27 degrees and completely adjusted my tb idle valve. I'm still getting my high idle. I've removed and sprayed the AAR, ohmed out to 13 ohms, applied 12vdc to check it out and it works. (IMG:style_emoticons/default/WTF.gif)
- Lo-Fi Version Time is now: 22nd April 2025 - 11:21 AM
