URGENT question about headlight motor, possibly leave me stranded tonight?? |
jsayre914 |
Feb 1 2013, 11:07 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I noticed that when I drove to work this morning, and parked. The driverside headlight bucket must be clogged, and the rain water has frozen solid. When I turned the headlights off to go into work, the headlight is raised about 1 inch. It will not close all the way due to the ice block beneath.
Is the motor still energized trying to close the headlight???? If it is I am sure it will kill the battery by the time I get off in 10 hours. PLEASE LET ME KNOW. if it is going to kill the battery, should i pop them up, pull the relay from that side and then shut them off. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
zambezi |
Feb 1 2013, 11:55 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Yes I would pull the relays on both sides and manually raise them until you can defrost the ice blocking them.
Lo-Fi Version | Time is now: 26th June 2024 - 03:21 AM |
