MrHyde |
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None ![]() |
I'm looking for the thin 32MM (1 1/4")wrench required to put turbo tie rod in the 914.. I had it all put in and then realized I forgot the spacers. Once that was put in my wrench just wont get in there. I could grind it down, but figured I'd see if I can get ahold of the proper tool instead. I can't seem to find one online so far.
Also looking for the socket to install the balljoint lock nut.. Thanks, Mike |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
The ball joint tool I probably could make something that works.
The wrench I'd just go to Princess Auto, buy a cheap wrench and grind it down. I'll look at this tomorrow (Monday) for you. |
Lo-Fi Version | Time is now: 1st July 2024 - 02:15 PM |
