grogthegreat |
Newbie ![]() Group: Members Posts: 5 Joined: 17-February 12 From: SanDiego, CA Member No.: 14,139 Region Association: None ![]() |
Anyone have the two plastic fuel lines from the engine compartment?
One of mine on my 74 got partially melted through because it was touching the main battery cable when it shorted to the underside of the trunk near the starter! It feels like it it about to burst and I don't want to waste any expensive fuel! Let me know how much you want with shipping to Escondido CA (92026) Thanks! -Grog |
grogthegreat |
I considered it but everything else about the car is so original and stock that I'd prefer to keep it that way. Not as important, but I figured that a set of good used plastic lines would also be cheaper than new stainless steel ones.
Rockaria |
ZippidyDoDah... ![]() ![]() ![]() Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None ![]() |
I considered it but everything else about the car is so original and stock that I'd prefer to keep it that way. Not as important, but I figured that a set of good used plastic lines would also be cheaper than new stainless steel ones. This is one place I broke the "My Car is perfectly stock" rule. Those stainless steel lines look better, work perfect, and will give you piece of mind. Besides the engine bay lines are only about $50 a set and the Tunnel ones about $80 a set. Best investment you can make. They should change the concours rules to add points for having them! |
Lo-Fi Version | Time is now: 26th June 2024 - 09:59 AM |
