> Testing Original Custom's Upgraded Speedo Drive Seals, Initial impressions and installation.
Sleepin
post Mar 18 2010, 09:14 PM
My wife's '73 was leaking a huge amount of oil out of the speedo drive. I contacted McMark to try out his newly designed speedo drive.
As you can see, this drive was leaking quite a bit. Just sitting in the garage it would drain out a major spot just in a couple days.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017475.1.jpg)
Here is my core sitting next to the new unit. Notice the extra O-ring:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017476.2.jpg)
The swap was straight forward. The only difference I noticed from a regular speedo drive was a little persuasion required to very lightly tap the drive into position. I just used a small rubber mallet to accomplish this. I am confident that I did not pinch the O-rings, and it felt like a good solid seal. Once in place without the set screw in, I could not wiggle or move the drive from side to side at all.
A quick fill of the trans:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017477.3.jpg)
A quick wipedown to get rid of any oil:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017477.4.jpg)
Also put a strip of cardboard underneath the trans...I want to make sure this isn't going to leak.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-179-1269017478.5.jpg)
I will snap another picture underneath in a couple days. I highly doubt that this will leak at all! Such a good idea IMO...I wonder why no one thought of this before!
McMark
post May 31 2010, 06:37 PM
914 Freak!
Nope, there is the single screw, then it just pulls out. Drain the transmission or raise the ass end a lot or you'll get a nice stinky gear oil shower. (IMG:style_emoticons/default/cool.gif)
john_g
post Feb 5 2013, 06:59 PM
QUOTE(McMark @ May 31 2010, 04:37 PM) *
Nope, there is the single screw, then it just pulls out. Drain the transmission or raise the ass end a lot or you'll get a nice stinky gear oil shower. B)
Mark,
I just got onto this thread (did a search as soon as I diagnosed the source of the leak). I want to remove the speedo drive, but ... where the heck is the set screw?? (I have a side shifter, if that makes any difference).
- Lo-Fi Version Time is now: 19th April 2025 - 02:44 AM
