> Megasquirt Project, .....IT RUNS !
Michelj13
post Sep 1 2012, 07:45 PM
Hi,
Although I have been a member for a while (since I purchased my 914), I have not posted much. I still love my 914 and it's is interesting how this car drives like an absolute go-cart.
Anyway, my engine is a carbed 2270 that I built up with the help of many including Jake, and I am now embarking on a Megasquirt project. As many know, megasquirt is relatively inexpensive for a programmable FI system. I find, however, that there is too much information out there that it is nothing short of confusing. I want to share my progress so that at the end of the day, some may learn and may become less intimidated. Hopefully I will be successful....we'll see.
I have so many questions that I will post, along with some things that I have already learned. ANY and ALL comments appreciated.
I made a youtube video of my progress up to date. Enjoy!
http://www.youtube.com/watch?v=RoJfMZ9YgQc
Michel (IMG:style_emoticons/default/smile.gif)
Michelj13
post Feb 6 2013, 12:27 AM
I am loving all the feedback. Thank you everyone. James, you are correct, I copied some of the tables from others (with earlier versions of code )that were trying to help me along. I cut and pasted parts of two different files (text) the best way I could think of. To be honest, I had not noticed the rpm jump around that jpnovak pointed out. It is obvious now that that is a huge mistake. This is a learning process, and actually, everything about this project is just that. I lot of fun though (IMG:style_emoticons/default/smile.gif)
Michelj13   Megasquirt Project, .....IT RUNS !   Sep 1 2012, 07:45 PM
aircooledtechguy   I have no doubts that your Megasquirt install will...   Sep 2 2012, 09:05 AM
Michelj13   I appreciate your comments Nate. I am still not ve...   Sep 2 2012, 12:54 PM
kg6dxn   I have built many EFI projects with various system...   Sep 2 2012, 10:24 AM
cgnj   Hi, You may want to search Dave Hunts 2270 projec...   Sep 2 2012, 10:42 AM
aircooledtechguy   Hi, You may want to search Dave Hunts 2270 proje...   Sep 2 2012, 11:52 AM
cgnj   Dave's is back to Megasquirt and running bett...   Sep 2 2012, 12:53 PM
aircooledtechguy   Dave's is back to Megasquirt and running bet...   Sep 2 2012, 02:44 PM
cgnj   He switched to ITB and SDS. Then had issues with...   Sep 2 2012, 03:15 PM
aircooledtechguy   He switched to ITB and SDS. Then had issues wit...   Sep 2 2012, 09:05 PM
Tom   First that is a very nice bench set up and I am su...   Sep 2 2012, 03:39 PM
Michelj13   The plan is to use a 2L modified intake manifold w...   Sep 3 2012, 07:31 AM
McMark   Yup, the firing order and spark plug pairing is co...   Sep 3 2012, 10:52 AM
Michelj13   IIRC, the injectors are 1-4 and 2-3, and I imagin...   Sep 3 2012, 11:18 AM
aircooledtechguy   I'm not sure if microsquirt is different than ...   Sep 3 2012, 12:18 PM
wingnut86   Agreed with Tom, similar background as he has. Um...   Sep 3 2012, 03:27 PM
McMark   It's not the ECU/Brain that matters in inject...   Sep 4 2012, 12:19 PM
Michelj13   Can anyone comment on my settings? I put them all ...   Sep 4 2012, 11:49 PM
McMark   IIRC, the Tooth #1 Angle (top right box in your im...   Sep 5 2012, 11:37 AM
Michelj13   I am deleting this post, because information was n...   Sep 5 2012, 10:17 PM
aircooledtechguy   I will need to make another bench experiment, but...   Sep 6 2012, 10:22 AM
McMark   IMHO, timing should always be confirmed via timing...   Sep 6 2012, 11:57 AM
aircooledtechguy   IMHO, timing should always be confirmed via timin...   Sep 6 2012, 04:25 PM
Michelj13   Yes, I confirmed tonight that the Tooth #1 angle a...   Sep 6 2012, 11:57 PM
rwilner   boy this looks familiar! When you get into tu...   Sep 7 2012, 11:49 AM
Michelj13   boy this looks familiar! When you get into t...   Sep 8 2012, 09:23 AM
Michelj13   Just receive my SS "through the tunnel fuel l...   Sep 12 2012, 10:30 PM
Michelj13   Almost ready to pull fuel tank. You can probably t...   Oct 13 2012, 12:35 PM
toon1   Yes you are crazy!!! I think I would h...   Oct 13 2012, 08:00 PM
wingnut86   Actually, if you used Bacatdi 151 and Long Island ...   Oct 13 2012, 08:31 PM
Michelj13   I had some success this weekend :D The relay board...   Nov 13 2012, 09:21 AM
aircooledtechguy   :beer2: Glad to hear that you actually took it o...   Nov 13 2012, 12:15 PM
DBCooper   Thread title is "Will It Ever Run?" Now...   Nov 13 2012, 03:18 PM
Michelj13   I tried, but was unable to figure it out. I will s...   Nov 19 2012, 06:22 PM
ConeDodger   I tried, but was unable to figure it out. I will ...   Nov 19 2012, 07:00 PM
rudedude   Step up the pace! I want to do microsquirt th...   Nov 19 2012, 07:24 PM
Michelj13   Ok, the title is changed, yeh me. I only work in o...   Nov 20 2012, 12:01 AM
McMark   Unfortunately that location won't give you tru...   Nov 20 2012, 09:53 AM
Michelj13   I knew this when I decided to go this route. I ha...   Nov 20 2012, 02:50 PM
Michelj13   Some good progress over the last few weeks. Finall...   Dec 13 2012, 06:33 PM
rwilner   Some good progress over the last few weeks. Final...   Dec 13 2012, 08:15 PM
McMark   The MSQ stores all the settings, so if you've ...   Dec 13 2012, 10:57 PM
Michelj13   Thanks for that heads up info. I did not realize...   Dec 14 2012, 12:14 AM
McMark   Notes are always good anyway. ;) The MSQ is just...   Dec 14 2012, 12:19 AM
aircooledtechguy   :agree: Save a copy of the MSQ after you're ...   Dec 14 2012, 12:30 AM
Michelj13   I am comparing "rwilner"s msq file with ...   Dec 14 2012, 09:25 PM
Michelj13   Just a few progress photos. I invite all comments ...   Dec 14 2012, 09:55 PM
Michelj13   I had the whole day from 8 am to 5 pm to work on m...   Jan 21 2013, 07:34 PM
wndsrfr   I had the whole day from 8 am to 5 pm to work on ...   Jan 21 2013, 09:00 PM
kg6dxn   :Qarl: :beer3:   Jan 21 2013, 07:35 PM
FourBlades   Nice progress! :trophy: You will get it se...   Jan 21 2013, 07:54 PM
Michelj13   This weekend, I had chance to spend a couple of ho...   Feb 4 2013, 06:52 PM
JamesM   Step 1: Make sure you are firing on all 4. No poi...   Feb 5 2013, 12:50 AM
DBCooper   http://www.914world.com/bbs2/uploads_offsite/i379....   Feb 5 2013, 08:22 AM
Michelj13   James, Step 1: I have checked that all cylinders ...   Feb 5 2013, 10:33 AM
JamesM   :agree: x2, getting the engine started the first t...   Feb 5 2013, 10:16 PM
JamesM   A couple things I might recommending changing on y...   Feb 5 2013, 10:30 PM
jpnovak   WTF? Why do you have an rpm values that go from 7...   Feb 5 2013, 09:30 PM
kg6dxn   The ECU looks at all surrounding blocks. Not just ...   Feb 5 2013, 10:38 PM
aircooledtechguy   :agree: with everything above. My VE table is abo...   Feb 5 2013, 10:55 PM
JamesM   :agree: with everything above. My VE table is ab...   Feb 5 2013, 11:09 PM
Michelj13   I am loving all the feedback. Thank you everyone. ...   Feb 6 2013, 12:27 AM
Michelj13   I spent a little time changing my .msq file. Plea...   Feb 6 2013, 03:24 PM
JamesM   Haven't had time to look over your MSQ yet (st...   Feb 6 2013, 03:58 PM
JamesM   Also, depending on where you are idleing you will ...   Feb 6 2013, 04:05 PM
jpnovak   Much better. You will find it much easier to adju...   Feb 6 2013, 04:04 PM
kg6dxn   3700 rpm @ 85% load needs to be smoothed out. If y...   Feb 6 2013, 08:18 PM
Michelj13   I could not wait until tomorrow. I changed the adv...   Feb 6 2013, 09:35 PM
JamesM   humm... I would think MAP should be a lot lower t...   Feb 7 2013, 05:32 PM
kg6dxn   As you start to tune, play with only one setting. ...   Feb 6 2013, 10:19 PM
Michelj13   Interesting. I spoke to Jake personally on a cou...   Feb 7 2013, 10:28 PM
JamesM   I have read posts on other forums with people usin...   Feb 8 2013, 12:17 PM
Michelj13   Yes, today was a Big Day :D I drove it around th...   Feb 10 2013, 10:53 PM
toon1   80on your MAP at idle seems real high. i have ...   Feb 23 2013, 07:12 AM
Michelj13   Sunday, I had some time to do some tuning. I was a...   Mar 4 2013, 05:24 PM
JamesM   Sunday, I had some time to do some tuning. I was ...   Mar 4 2013, 06:14 PM
Michelj13   James, I wish I had a good idle at 5 degrees of a...   Mar 4 2013, 09:03 PM
jpnovak   If you set 5 ATDC timing in TunerStudio (or Megatu...   Mar 4 2013, 09:30 PM
Michelj13   I have a wideband O2 sensor from AEM. At idle, AFR...   Mar 4 2013, 09:51 PM
JamesM   You need to be absolutely sure that the timing you...   Mar 4 2013, 11:51 PM
jpnovak   James, Excellent description of the process to ba...   Mar 5 2013, 12:43 PM
Michelj13   I had a bit of a breakthrough last night. I swappe...   Mar 6 2013, 08:56 AM
JamesM   Stay away from Alpha-N for now, that should be the...   Mar 6 2013, 12:50 PM
Michelj13   Well, I have been fighting a few issues before goi...   Mar 11 2013, 10:27 PM
Sneezy   So you guys are spending hundreds and hundreds of ...   Mar 12 2013, 07:48 AM
JamesM   So you guys are spending hundreds and hundreds of...   Mar 12 2013, 09:36 AM
ddv005   So you guys are spending hundreds and hundreds of...   Oct 30 2013, 08:21 PM
DBCooper   No. But what's your point, really? .   Mar 12 2013, 07:56 AM
jpnovak   Glad to hear you found the vacuum leak. did this ...   Mar 12 2013, 08:27 AM
FourBlades   Great progress. I have enjoyed following this th...   Mar 12 2013, 10:44 AM
JamesM   Great progress. I have enjoyed following this t...   Mar 12 2013, 10:55 AM
Michelj13   JP. I like your your idea of re-scaling my MAP tab...   Mar 12 2013, 05:36 PM
Michelj13   After a rather long hiatus, I will attempt to get ...   Nov 30 2014, 07:41 PM
McMark   Didn't read the whole thread, but did see the ...   Nov 30 2014, 08:41 PM
Michelj13   Hi Mark, I did noticed the 1+3 and 2+4 injector p...   Nov 30 2014, 08:59 PM
Mike Bellis   I think the effect on a batch fire injector out of...   Nov 30 2014, 10:02 PM
Michelj13   As I have said in the past, I am slow but steady. ...   Mar 17 2015, 01:10 AM
toon1   As I have said in the past, I am slow but steady....   Mar 17 2015, 11:23 AM
Michelj13   Tooni, thanks for info. LS coils are presently con...   Mar 17 2015, 12:36 PM
toon1   Tooni, thanks for info. LS coils are presently co...   Mar 17 2015, 01:21 PM
33 User(s) are reading this topic (33 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 05:23 AM
