grogthegreat |
Newbie ![]() Group: Members Posts: 5 Joined: 17-February 12 From: SanDiego, CA Member No.: 14,139 Region Association: None ![]() |
Anyone have the two plastic fuel lines from the engine compartment?
One of mine on my 74 got partially melted through because it was touching the main battery cable when it shorted to the underside of the trunk near the starter! It feels like it it about to burst and I don't want to waste any expensive fuel! Let me know how much you want with shipping to Escondido CA (92026) Thanks! -Grog |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Were the fuel lines originally white and turned brown with age, Jeff?
Those look like the tubing supplied with the under-sink water filter system we just installed, probably rated at the same PSI too. |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Were the fuel lines originally white and turned brown with age, Jeff? Those look like the tubing supplied with the under-sink water filter system we just installed, probably rated at the same PSI too. Yep white, which is translucent with fuel in it. That undersink tubing is simple polyethylene. Nope. PEX? Nope. The material is Polyamide 11, otherwise known as Nylon 11. You can google its properties. I verified this info from an NOS piece. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:58 AM |
