> Megasquirt Project, .....IT RUNS !
Michelj13
post Sep 1 2012, 07:45 PM
Hi,
Although I have been a member for a while (since I purchased my 914), I have not posted much. I still love my 914 and it's is interesting how this car drives like an absolute go-cart.
Anyway, my engine is a carbed 2270 that I built up with the help of many including Jake, and I am now embarking on a Megasquirt project. As many know, megasquirt is relatively inexpensive for a programmable FI system. I find, however, that there is too much information out there that it is nothing short of confusing. I want to share my progress so that at the end of the day, some may learn and may become less intimidated. Hopefully I will be successful....we'll see.
I have so many questions that I will post, along with some things that I have already learned. ANY and ALL comments appreciated.
I made a youtube video of my progress up to date. Enjoy!
http://www.youtube.com/watch?v=RoJfMZ9YgQc
Michel (IMG:style_emoticons/default/smile.gif)
Michelj13
post Feb 6 2013, 09:35 PM
I could not wait until tomorrow. I changed the advance to 10 degrees at 900 and 1200 and smoothed out the VE table. It started right up, but was a bit rough. I changed the injector pairing from 1-4, 2-3 to 1-3, 2-4 and idle got a lot smoother.
It got dark and looks like I ran out of gas again (IMG:style_emoticons/default/sad.gif)
I am starting to get a feel for it, but, the whole concept of VE and how it relates to fuel enrichment is not very clear to me. At idle (1000RPM), MAP was reading 80. and fuel load was 85%. I think VE was 65. Does this make sense?
I tought TS had a logger, but, could not find it.
JamesM
post Feb 7 2013, 05:32 PM
humm... I would think MAP should be a lot lower then 80, though the cam may have a lot to do with that. I just looked up the 9530 and jake states on his site that it is not compatable with ANY injection, stock or aftermarket. I also saw another ports where he recomends not using the 9530 on a 2270. Im not sure what affect this is going to have when tunning, might just make it more fun.
When you get to starting it up again check the AFR at idle try and get it adjusted down to around 12.8 (i have a feeling you are lean) Also maybe double check the actual timing with a timming light again. Let us know the MAP reading once this is done. I would hope to see the MAP reading down to at least 50 if not in the 30s.
Worst case i think if the cam doesent produce good vaccum is that you could switch over to alpha-n fueling. lets not jump there just yet though.
QUOTE(Michelj13 @ Feb 6 2013, 08:35 PM) *
Michelj13   Megasquirt Project, .....IT RUNS !   Sep 1 2012, 07:45 PM
aircooledtechguy   I have no doubts that your Megasquirt install will...   Sep 2 2012, 09:05 AM
Michelj13   I appreciate your comments Nate. I am still not ve...   Sep 2 2012, 12:54 PM
kg6dxn   I have built many EFI projects with various system...   Sep 2 2012, 10:24 AM
cgnj   Hi, You may want to search Dave Hunts 2270 projec...   Sep 2 2012, 10:42 AM
aircooledtechguy   Hi, You may want to search Dave Hunts 2270 proje...   Sep 2 2012, 11:52 AM
cgnj   Dave's is back to Megasquirt and running bett...   Sep 2 2012, 12:53 PM
aircooledtechguy   Dave's is back to Megasquirt and running bet...   Sep 2 2012, 02:44 PM
cgnj   He switched to ITB and SDS. Then had issues with...   Sep 2 2012, 03:15 PM
aircooledtechguy   He switched to ITB and SDS. Then had issues wit...   Sep 2 2012, 09:05 PM
Tom   First that is a very nice bench set up and I am su...   Sep 2 2012, 03:39 PM
Michelj13   The plan is to use a 2L modified intake manifold w...   Sep 3 2012, 07:31 AM
McMark   Yup, the firing order and spark plug pairing is co...   Sep 3 2012, 10:52 AM
Michelj13   IIRC, the injectors are 1-4 and 2-3, and I imagin...   Sep 3 2012, 11:18 AM
aircooledtechguy   I'm not sure if microsquirt is different than ...   Sep 3 2012, 12:18 PM
wingnut86   Agreed with Tom, similar background as he has. Um...   Sep 3 2012, 03:27 PM
McMark   It's not the ECU/Brain that matters in inject...   Sep 4 2012, 12:19 PM
Michelj13   Can anyone comment on my settings? I put them all ...   Sep 4 2012, 11:49 PM
McMark   IIRC, the Tooth #1 Angle (top right box in your im...   Sep 5 2012, 11:37 AM
Michelj13   I am deleting this post, because information was n...   Sep 5 2012, 10:17 PM
aircooledtechguy   I will need to make another bench experiment, but...   Sep 6 2012, 10:22 AM
McMark   IMHO, timing should always be confirmed via timing...   Sep 6 2012, 11:57 AM
aircooledtechguy   IMHO, timing should always be confirmed via timin...   Sep 6 2012, 04:25 PM
Michelj13   Yes, I confirmed tonight that the Tooth #1 angle a...   Sep 6 2012, 11:57 PM
rwilner   boy this looks familiar! When you get into tu...   Sep 7 2012, 11:49 AM
Michelj13   boy this looks familiar! When you get into t...   Sep 8 2012, 09:23 AM
Michelj13   Just receive my SS "through the tunnel fuel l...   Sep 12 2012, 10:30 PM
Michelj13   Almost ready to pull fuel tank. You can probably t...   Oct 13 2012, 12:35 PM
toon1   Yes you are crazy!!! I think I would h...   Oct 13 2012, 08:00 PM
wingnut86   Actually, if you used Bacatdi 151 and Long Island ...   Oct 13 2012, 08:31 PM
Michelj13   I had some success this weekend :D The relay board...   Nov 13 2012, 09:21 AM
aircooledtechguy   :beer2: Glad to hear that you actually took it o...   Nov 13 2012, 12:15 PM
DBCooper   Thread title is "Will It Ever Run?" Now...   Nov 13 2012, 03:18 PM
Michelj13   I tried, but was unable to figure it out. I will s...   Nov 19 2012, 06:22 PM
ConeDodger   I tried, but was unable to figure it out. I will ...   Nov 19 2012, 07:00 PM
rudedude   Step up the pace! I want to do microsquirt th...   Nov 19 2012, 07:24 PM
Michelj13   Ok, the title is changed, yeh me. I only work in o...   Nov 20 2012, 12:01 AM
McMark   Unfortunately that location won't give you tru...   Nov 20 2012, 09:53 AM
Michelj13   I knew this when I decided to go this route. I ha...   Nov 20 2012, 02:50 PM
Michelj13   Some good progress over the last few weeks. Finall...   Dec 13 2012, 06:33 PM
rwilner   Some good progress over the last few weeks. Final...   Dec 13 2012, 08:15 PM
McMark   The MSQ stores all the settings, so if you've ...   Dec 13 2012, 10:57 PM
Michelj13   Thanks for that heads up info. I did not realize...   Dec 14 2012, 12:14 AM
McMark   Notes are always good anyway. ;) The MSQ is just...   Dec 14 2012, 12:19 AM
aircooledtechguy   :agree: Save a copy of the MSQ after you're ...   Dec 14 2012, 12:30 AM
Michelj13   I am comparing "rwilner"s msq file with ...   Dec 14 2012, 09:25 PM
Michelj13   Just a few progress photos. I invite all comments ...   Dec 14 2012, 09:55 PM
Michelj13   I had the whole day from 8 am to 5 pm to work on m...   Jan 21 2013, 07:34 PM
wndsrfr   I had the whole day from 8 am to 5 pm to work on ...   Jan 21 2013, 09:00 PM
kg6dxn   :Qarl: :beer3:   Jan 21 2013, 07:35 PM
FourBlades   Nice progress! :trophy: You will get it se...   Jan 21 2013, 07:54 PM
Michelj13   This weekend, I had chance to spend a couple of ho...   Feb 4 2013, 06:52 PM
JamesM   Step 1: Make sure you are firing on all 4. No poi...   Feb 5 2013, 12:50 AM
DBCooper   http://www.914world.com/bbs2/uploads_offsite/i379....   Feb 5 2013, 08:22 AM
Michelj13   James, Step 1: I have checked that all cylinders ...   Feb 5 2013, 10:33 AM
JamesM   :agree: x2, getting the engine started the first t...   Feb 5 2013, 10:16 PM
JamesM   A couple things I might recommending changing on y...   Feb 5 2013, 10:30 PM
jpnovak   WTF? Why do you have an rpm values that go from 7...   Feb 5 2013, 09:30 PM
kg6dxn   The ECU looks at all surrounding blocks. Not just ...   Feb 5 2013, 10:38 PM
aircooledtechguy   :agree: with everything above. My VE table is abo...   Feb 5 2013, 10:55 PM
JamesM   :agree: with everything above. My VE table is ab...   Feb 5 2013, 11:09 PM
Michelj13   I am loving all the feedback. Thank you everyone. ...   Feb 6 2013, 12:27 AM
Michelj13   I spent a little time changing my .msq file. Plea...   Feb 6 2013, 03:24 PM
JamesM   Haven't had time to look over your MSQ yet (st...   Feb 6 2013, 03:58 PM
JamesM   Also, depending on where you are idleing you will ...   Feb 6 2013, 04:05 PM
jpnovak   Much better. You will find it much easier to adju...   Feb 6 2013, 04:04 PM
kg6dxn   3700 rpm @ 85% load needs to be smoothed out. If y...   Feb 6 2013, 08:18 PM
Michelj13   I could not wait until tomorrow. I changed the adv...   Feb 6 2013, 09:35 PM
JamesM   humm... I would think MAP should be a lot lower t...   Feb 7 2013, 05:32 PM
kg6dxn   As you start to tune, play with only one setting. ...   Feb 6 2013, 10:19 PM
Michelj13   Interesting. I spoke to Jake personally on a cou...   Feb 7 2013, 10:28 PM
JamesM   I have read posts on other forums with people usin...   Feb 8 2013, 12:17 PM
Michelj13   Yes, today was a Big Day :D I drove it around th...   Feb 10 2013, 10:53 PM
toon1   80on your MAP at idle seems real high. i have ...   Feb 23 2013, 07:12 AM
Michelj13   Sunday, I had some time to do some tuning. I was a...   Mar 4 2013, 05:24 PM
JamesM   Sunday, I had some time to do some tuning. I was ...   Mar 4 2013, 06:14 PM
Michelj13   James, I wish I had a good idle at 5 degrees of a...   Mar 4 2013, 09:03 PM
jpnovak   If you set 5 ATDC timing in TunerStudio (or Megatu...   Mar 4 2013, 09:30 PM
Michelj13   I have a wideband O2 sensor from AEM. At idle, AFR...   Mar 4 2013, 09:51 PM
JamesM   You need to be absolutely sure that the timing you...   Mar 4 2013, 11:51 PM
jpnovak   James, Excellent description of the process to ba...   Mar 5 2013, 12:43 PM
Michelj13   I had a bit of a breakthrough last night. I swappe...   Mar 6 2013, 08:56 AM
JamesM   Stay away from Alpha-N for now, that should be the...   Mar 6 2013, 12:50 PM
Michelj13   Well, I have been fighting a few issues before goi...   Mar 11 2013, 10:27 PM
Sneezy   So you guys are spending hundreds and hundreds of ...   Mar 12 2013, 07:48 AM
JamesM   So you guys are spending hundreds and hundreds of...   Mar 12 2013, 09:36 AM
ddv005   So you guys are spending hundreds and hundreds of...   Oct 30 2013, 08:21 PM
DBCooper   No. But what's your point, really? .   Mar 12 2013, 07:56 AM
jpnovak   Glad to hear you found the vacuum leak. did this ...   Mar 12 2013, 08:27 AM
FourBlades   Great progress. I have enjoyed following this th...   Mar 12 2013, 10:44 AM
JamesM   Great progress. I have enjoyed following this t...   Mar 12 2013, 10:55 AM
Michelj13   JP. I like your your idea of re-scaling my MAP tab...   Mar 12 2013, 05:36 PM
Michelj13   After a rather long hiatus, I will attempt to get ...   Nov 30 2014, 07:41 PM
McMark   Didn't read the whole thread, but did see the ...   Nov 30 2014, 08:41 PM
Michelj13   Hi Mark, I did noticed the 1+3 and 2+4 injector p...   Nov 30 2014, 08:59 PM
Mike Bellis   I think the effect on a batch fire injector out of...   Nov 30 2014, 10:02 PM
Michelj13   As I have said in the past, I am slow but steady. ...   Mar 17 2015, 01:10 AM
toon1   As I have said in the past, I am slow but steady....   Mar 17 2015, 11:23 AM
Michelj13   Tooni, thanks for info. LS coils are presently con...   Mar 17 2015, 12:36 PM
toon1   Tooni, thanks for info. LS coils are presently co...   Mar 17 2015, 01:21 PM
36 User(s) are reading this topic (36 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 05:14 AM
