| tscrihfield |
Feb 11 2013, 05:25 PM
Drive Fast and Take Chances ![]() ![]() ![]() Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None
So, I have lived about a quarter mile away from a 74 911T for 5 years and never knew it. It has a 2.7 in it and CIS. The car is a lost cause, but complete with engine trans. It has sat for a few years outside but the engine still turns over. Really all I'm after is the engine in it if it is a good buy. It does have a nice set of Fuchs on it...
What are all of your thoughts of its worth? I will most likely buy the whole car and sell everything minus the engine. |
| pcar916 |
Feb 11 2013, 06:19 PM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
What kind of mileage is on that powertrain? I had a carburated 2.7L, also from a '75 car, in my 914 when I bought it. It was excellent, but the PO had had the engine totally bulletproofed (via the Bruce Andersen "E" specs in his book. That included better head studs/timecerts, head work, cams, a larger oil pump and even the shuffle-pins one really doesn't need as much as once was thought.
I loved that engine and traded it (along with some cash in his general direction) for the current 3.6 to friend of mine, at his request, when he wanted it for his track 911 built to class rules. I've built several since then and here's my take. It's a fine engine when rebuilt around it's faults. It's on the outside of what it's magnesium case can handle so time-certs and deleting the dilivar studs are a requirement. Unless you know exactly what engine work has been done I would go for a 3.0, 3.2, or, if your budget can do it, a 3.6 liter engine every time. A rebuild on the 2.7 including the machine work needed to insure that the case-halves go together and the bearing journals are right and with all of the shop work you'll need, it's as much or more $ to build as a 3.0 or a 3.2 liter engine... and it won't last as many miles until the next rebuild as the later engines will. I'd get a newer one but it'll be a fun machine any way you cut it. You'll get a lot of miles from the other parts on the car no matter what you do just for conversion goodies if they're in good shape. If the engine is a core, I'd offer him $1000-$1500 based on the restoration costs. Redoing one of those drivetrains is very expensive. You can use the front struts, the transaxle flanges, stub axles, and rear rotors to do your 100mm CV and 5-lug conversion regardless of the engine transplant. Good luck |
| Randal |
Feb 11 2013, 11:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
What kind of mileage is on that powertrain? I had a carburated 2.7L, also from a '75 car, in my 914 when I bought it. It was excellent, but the PO had had the engine totally bulletproofed (via the Bruce Andersen "E" specs in his book. That included better head studs/timecerts, head work, cams, a larger oil pump and even the shuffle-pins one really doesn't need as much as once was thought. I loved that engine and traded it (along with some cash in his general direction) for the current 3.6 to friend of mine, at his request, when he wanted it for his track 911 built to class rules. I've built several since then and here's my take. It's a fine engine when rebuilt around it's faults. It's on the outside of what it's magnesium case can handle so time-certs and deleting the dilivar studs are a requirement. Unless you know exactly what engine work has been done I would go for a 3.0, 3.2, or, if your budget can do it, a 3.6 liter engine every time. A rebuild on the 2.7 including the machine work needed to insure that the case-halves go together and the bearing journals are right and with all of the shop work you'll need, it's as much or more $ to build as a 3.0 or a 3.2 liter engine... and it won't last as many miles until the next rebuild as the later engines will. I'd get a newer one but it'll be a fun machine any way you cut it. You'll get a lot of miles from the other parts on the car no matter what you do just for conversion goodies if they're in good shape. If the engine is a core, I'd offer him $1000-$1500 based on the restoration costs. Redoing one of those drivetrains is very expensive. You can use the front struts, the transaxle flanges, stub axles, and rear rotors to do your 100mm CV and 5-lug conversion regardless of the engine transplant. Good luck + 1 on a 3.6. Once installed they will last forever and need about zero maintenance. And with 300HP they are just stunningly fast. I also love 2.7, after all the mods have been done. They just scream, but once you drive a 3.6 in the same car there is no comparison. (IMG:style_emoticons/default/biggrin.gif) |
tscrihfield Found a good donor for a 6 Feb 11 2013, 05:25 PM
GeorgeRud When I did my conversion, I used a rusted 75 Targa... Feb 11 2013, 05:31 PM
tscrihfield
When I did my conversion, I used a rusted 75 Targ... Feb 11 2013, 05:40 PM
rfuerst911sc I'd offer 1500.00 Feb 11 2013, 05:50 PM
tscrihfield
I'd offer 1500.00
I just got off the phone... Feb 11 2013, 06:07 PM
tscrihfield Thanks for the info Pcar!
I am trying to ke... Feb 11 2013, 06:37 PM
pcar916 Not all '75's were weak. If you can find a... Feb 11 2013, 07:01 PM
brant there aren't any aluminum (original) 2.4 motor... Feb 11 2013, 07:18 PM
pcar916
... there aren't any aluminum (original) 2.4 ... Feb 12 2013, 08:08 AM
sixnotfour In 74 there was a 911 and a 911S.. one has bigger ... Feb 11 2013, 08:31 PM
carr914
there aren't any aluminum (original) 2.4 moto... Feb 11 2013, 09:52 PM
Van914 Thomas,
Buy it for $1,500.
You will not be so... Feb 12 2013, 01:00 PM
tscrihfield
Thomas,
Buy it for $1,500.
You will not be s... Feb 13 2013, 06:36 PM
bigkensteele
Thomas,
Buy it for $1,500.
You will not be ... Feb 13 2013, 09:16 PM
914itis Can I send back the boxter wheels in exchange for ... Feb 13 2013, 07:11 PM
tscrihfield
Can I send back the boxter wheels in exchange for... Feb 13 2013, 07:13 PM
914itis
Can I send back the boxter wheels in exchange fo... Feb 17 2013, 06:52 PM
sixnotfour Bright trim and swing out windows.......good ... Feb 13 2013, 09:24 PM
tscrihfield http://www.914world.com/bbs2/uploads_offsite/i163.... Feb 17 2013, 10:33 AM
beech4rd The rear of that car has a couple of valuable part... Feb 17 2013, 01:21 PM
Spoke Looks nice. The Fuchs alone have to worth north of... Feb 17 2013, 05:11 PM
Spoke
Looks nice. The Fuchs alone have to be worth nort... Feb 17 2013, 05:11 PM
falconfp2001
Looks nice. The Fuchs alone have to worth north o... Feb 17 2013, 07:06 PM
KENNY I would love to restore that 911. Value has gone u... Feb 17 2013, 07:12 PM
Porschef I bought a 75 911s in California in 1990. Had no i... Feb 17 2013, 07:23 PM
tscrihfield Thanks guys for all of your input. I am going to ... Feb 17 2013, 07:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st September 2026 - 12:43 PM |
