JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
I am replacing my plastic tunnel fuel lines that go to the fuel tank with stainless steel lines.
My question is this: The rubber hoses that goes from tank to fuel line, do you disconnect and connect from steering cover underneath or do you allow enough hoses to do it from the top? Thank you in advance for your answer. |
JawjaPorsche |
The fuel pump was moved to engine firewall 15 years ago and it solved the dreaded vapor lock. Happen once in Arizona where it was 110 degrees. State Patrol stopped and said when it finally starts to run your heater! Thank goodness I could take the top off!
Black22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 08:43 AM |
