JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
I am replacing my plastic tunnel fuel lines that go to the fuel tank with stainless steel lines.
My question is this: The rubber hoses that goes from tank to fuel line, do you disconnect and connect from steering cover underneath or do you allow enough hoses to do it from the top? Thank you in advance for your answer. |
JawjaPorsche |
The fuel pump was moved to engine firewall 15 years ago and it solved the dreaded vapor lock. Happen once in Arizona where it was 110 degrees. State Patrol stopped and said when it finally starts to run your heater! Thank goodness I could take the top off!
Black22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest ![]() |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Happen once in Arizona where it was 110 degrees. State Patrol stopped and said when it finally starts to run your heater! That will work for a water cooled car. I don't think it does a thing for our cars. Actually, the trooper was right. Turning on the heater will direct the hot air into the cabin instead of dupming it all on the fuel pump. Not really something I would want to do, but being 130 degrees in the cabin is still better than sitting on the side of the road till it cools down. |
walterolin |
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States ![]() |
Happen once in Arizona where it was 110 degrees. State Patrol stopped and said when it finally starts to run your heater! That will work for a water cooled car. I don't think it does a thing for our cars. Actually, the trooper was right. Turning on the heater will direct the hot air into the cabin instead of dupming it all on the fuel pump. Not really something I would want to do, but being 130 degrees in the cabin is still better than sitting on the side of the road till it cools down. I discovered this with my '70 some years back, got vapor lock a few times on the interstate in hot weather, and the "turn on the heater" trick worked. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:54 AM |
