JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
I was reading K&N's website about their air filters:
High flow air filters designed to improve engine performance Designed to increase horsepower, torque, and acceleration Has anyone put these on their stock FI Teeners and experience any of the above? I am talking about the filters that go in our stock air filter boxes. Not external modification filters. I noticed Pelican Parts sells then as an option. http://www.pelicanparts.com/cgi-bin/smart/...76%29%2C%20Each |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
I'm here! Sorry I'm late, I was sleeping, or maybe having a life, or something ............. If you're measuring HP using intake noise levels, the increase is huge. If you're measuring engine life resulting from the increase in contaminants being drawn in through the intake, the drop is likely to be significant. Put plainly, the square inches of filter material is often reduced from that of the OE filter by 2 or 3 (or more) times. How do they get higher flow through a smaller area? They make the pores larger, allowing more and larger particles to pass through, along with the air. Coating the filter with oil helps a little, but what about the particles that don't touch the coating?
Think about the initial cost. Think about the cost of the service kit, and the time it takes to do the service, including the drying time after you wash the filter. Sound like something you want to do? Finally, think about that grit you've allowed inside your cylinders, grit that would have been stopped by your "antiquated" but very efficient paper air filter. You know, the one the factory specified when they designed the engine? The Cap'n |
Lo-Fi Version | Time is now: 26th June 2024 - 11:08 AM |
