RonW |
Member ![]() ![]() Group: Members Posts: 76 Joined: 31-December 05 From: Alameda, CA Member No.: 5,340 Region Association: Northern California ![]() |
Hey guys, I know its not a 914 but hoping to share info and request help on my project since the 912 board is fairly devoid of these conversions.
car is a '68 912 and last year I installed a 2005 STi Spec-C JDM motor and running the stock ecu and stripped down harness. I used an adapter plate and adapter flywheel and stage 2 Sach pp/clutch. for exhaust i used a pair of 2 into 1 header stubs that outback makes and brought each bank up to a turbo flange, then exhausted it to Coast Fabrication muffler. used twin turbosmart EWG with a locked out IWG. on the inlet side, ran it thru the stock MAF thru the turbo to a water/air intercooler and a turbosmart BOV up front im running a ron davis radiator and a fuel safe fuel cell with the mostly bent tubing run under the car just inboard of the pinch seam, similar to how the factory ran the oil cooler lines and short sections of 1.25" hose connecting. with the stock ecu ive have the stock tach sent in to North Hollywood Speedo to modify to take the ecu tach signal and redo the face to 8k redline the rest of the car is set up with 82SC front end and fresh Bilsteins and elephant polybronze bushes all around and lowered ride height. So that was phase one and been running her for the last 4 months or so. drove from SF area to Santa cruz and if i kept the revs at 3k then got 30 mpg but was only doing like 60 mph. if i increased to 75mph then 3400rpm and 24mpg. so i decided to go down this subaru path yet further and scored and 2010 WRX 5 speed that only had 20k miles on it. I am swapping in a reveres ring and pinion and will utilize 930 adapter flanges. Problem: one of many come with this swap for a 901 bodied car. 1) 930 axle wont bolt to the short wheel base trailing arms - solution, take later model LWB and have them modified to SWB dimensions by a shop that has a jig for this very mod. this will then allow for clearance and use with those larger stub axle flanges. plus the bonus of bigger brake options - this should be straight forward 2) transaxle mount - modify stock or subaru mount to bolt to the stock location - again wont know til im there 3) shift rod - hoping to mate the stock shift rod and retain the wevo shifter set up but wont know until i get there. i wish i could cable shift like many here have with an MR2 but no room. THIS IS WHERE I NEED YOUR COLLECTIVE HELP 4) hydraulic slave for clutch - stock is obviously a cable actuated system and i really do not want to try to graft in a Tilton pedal cluster. any recommendations of making this work? ie cable actuation to some type of master to a slave??? any advise would be much appreciated and i hope i'm ok posting my 912 project here. |
RonW |
d914: yep, ive seen the video of how the Todd at subaru gears cuts down the case to make it essentially like a 915 so it turns out like this
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.subarugears.com-5340-1361126654.1.jpg) ill look into the sub cv to 930 mating but may end up being close to same price to cut down the 930 axle/respline and get a cv for the tranny. good option though thanks i'll look for some photos that you are referencing w regard to installing a hydraulic clutch. DBCooper: LOVE your build! it was a frequent reference during planning and build. Good to know about the tilton and the howe masters. does the pedal positioning feel the same as the stock pedals ie L to R offset? Jamie: hey man, miss talking to you. when you gonna be in SJ again, we should try to hook up again. you planning on the treffin this year? ive got an empty seat if you want. -Interesting your Honda MC set up, do you have pics? i'll try to search for your build thread so i can visualize it. -The stock slave is bolted to the top and is a push style but i was thinking of dumping that slave for a Wilwood and mount it as a pull from the other direction like DBCooper (IMG:http://www.914world.com/bbs2/uploads/post-4154-1249270963.jpg) -I've been somewhat gentle to the 901 in first. It's never leaked since I've resealed it at the time in put in the 914 3/4/5th gears but no there is a very slight leak at the intermediate plate so it must be feeling it on WOT pulls in 2nd when she is pulling like a freight train. a914622: the 2010 wrx is a ty758 and the clutch slave is mounted to the top so its facing the transmission bell housing to "Push" here is a shot of the tranny but i dont think you can see where it mounts. i'll try to get a better pic later (IMG:http://www.914world.com/bbs2/uploads_offsite/iwolfe.com-5340-1361126656.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/iwolfe.com-5340-1361126656.3.jpg) thanks again to everyone for the assistance. btw, i did forgot to give a big thanks to Britain Smith for all his advise on the install and getting the electrical up and running with the stock ecu/harness. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:53 PM |
