Installing Elephant Racing PolyBronze Bushings, have a question: Something doesn't look right... |
bfrymire |
May 28 2012, 07:40 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
I am in the process of installing a set of ER bushings. The instructings say and show that some alignment washers need to be installed betweend the bushing and the mount. The problem is, there is no room at all to insert the washers. Here's a pic. What is wrong?
And I know that I have the bushing installed pointing toward the camera. I just wanted to show the interference that I am seeing. This is a very snug fit... I hope that someone can shed some light on this... thanks -- brett |
rhodyguy |
May 30 2012, 06:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,106 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
wow. what's the story behind those? too cool.
k |
hwgunner |
May 31 2012, 02:43 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
wow. what's the story behind those? too cool. k Hey guys. the struts are a set of Bilsteins that Bret sent me. The spindles were raised and de-cambered (should that be cambered) to give more camber. An RSR coil over kit was installed and new inserts if I remember correctly. There is also a Rebel bump steer kit installed on the struts. Very nice set up with easy adjust-ability. Very similar to what i put on my 73 911. The A-arms were powder coated and had Elephant Poly Bronze bushings installed. Very cool stuff. jonathan hwgunner |
Steve |
Feb 18 2013, 10:01 AM
914 Guru Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
wow. what's the story behind those? too cool. k Hey guys. the struts are a set of Bilsteins that Bret sent me. The spindles were raised and de-cambered (should that be cambered) to give more camber. An RSR coil over kit was installed and new inserts if I remember correctly. There is also a Rebel bump steer kit installed on the struts. Very nice set up with easy adjust-ability. Very similar to what i put on my 73 911. The A-arms were powder coated and had Elephant Poly Bronze bushings installed. Very cool stuff. jonathan hwgunner Sorry for the hijack, but i heard a rumor that with this kit you have to strengthen the body at the top where the strut bolts up. Is this true or is this a straight bolt on with no mods? |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:45 PM |
