Installing Elephant Racing PolyBronze Bushings, have a question: Something doesn't look right... |
bfrymire |
May 28 2012, 07:40 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
I am in the process of installing a set of ER bushings. The instructings say and show that some alignment washers need to be installed betweend the bushing and the mount. The problem is, there is no room at all to insert the washers. Here's a pic. What is wrong?
And I know that I have the bushing installed pointing toward the camera. I just wanted to show the interference that I am seeing. This is a very snug fit... I hope that someone can shed some light on this... thanks -- brett |
rhodyguy |
Feb 18 2013, 10:05 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
iirc the instructions warn you NOT to torque everything down until the whole process is complete to avoid the pinching issue. i missed the at first on one side and had to open it up slightly with a pry bar. with the conical washers you leave them slightly loose and shake the front end to settle things in. if the washers haven't rotated to where they need to be you can build in a bind. when installing the poly/bronze you need to visualize where you need the zerk fitting to be. clocked just enough for access but not pointing down to the point where they are in the direct line of fire.
Lo-Fi Version | Time is now: 24th September 2024 - 01:07 PM |
