brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I've been doing a little research for a daily driver toyota....
thinking about changing oil brands and seeing what is out there for a flat tappet cam that is cheaper than Royal purple, and more available than brad penn anyways... lots and lots of guys post about using VR1 lately I found some valvolene materials that may be a typo someone independently tested the 2 valvolene racing oils, and the street legal version (found at the flaps) the tests show 800ppm zddp on the street legal oil and 1300ppm on the two not street legal oils. yet the valolene litterature claims 1300ppm on all of their grey bottled oils. I would like to tell everyone to check the API starburst on the bottle if your flaps, VR-1 is SM rated or street legal I am of the belief that you are NOT getting the zddp you need for our engines... |
brant |
there website looks positive
the scary thing that I found was someone had run independent tests of the VR1 and their test showed low zddp numbers, even though valvolene advertised differently.... I know one test doesn't prove everything I know the manufacture is claiming higher numbers perhaps it was a bad batch, or improper test? I don't trust them at this point and will just not use VR1 street legal oil again if it has an API SM rating I wouldn't trust it. injunmort, do you have a bottle in your garage of what you use? I'm curious what the API starburst might be on it? |
dlkawashima |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California ![]() |
there website looks positive the scary thing that I found was someone had run independent tests of the VR1 and their test showed low zddp numbers, even though valvolene advertised differently.... I know one test doesn't prove everything I know the manufacture is claiming higher numbers perhaps it was a bad batch, or improper test? I don't trust them at this point and will just not use VR1 street legal oil Do you have a link to this test that has you scared? EDIT Here is a test (obviously not the one that has you concerned) that gives VR-1 conventional motor oil a high rating. Maybe it'll calm your fears: dead link new link https://540ratblog.wordpress.com/2013/06/20...r-test-ranking/ |
Lo-Fi Version | Time is now: 26th June 2024 - 02:00 AM |
