> Here is a how to for dent removal Not just filling it up with plastic, Or... When your cracker jack box has a nasty surprise
rick 918-S
post Mar 1 2012, 10:01 PM
Hey nice rack! -Celette
Like I've said before. When your working on old cars you have to realize they are like a box of Cracker Jacks. Everyone has a surprise. In most cases it's a cheap nasty surprise. In this case The dent in this panel was not that bad. The problem became complicated but the person that filled it in. Instead of working the damage out the person took a pick hammer and drove about a hundred dents in the panel trying to chase high metal from the top of the panel being driven down. Normally I would just replace a panel that was damaged to this degree. But this is a special car. There is zero rust so I will take the time to bump the panel back into shape. There will still be a finishing glaze used but in a manor appropriate for restoration not amature night at the Drive Inn Autobody Shop.
Here's what I Found when I started stripping off the panel.
I used a Tig welding rod so you could see how deep the damage is.
Here are only some of the tools I used. I also used a couple wood blocks ground into different contours as a backer for shrinking.
I'm sure some of you have never really tried to work a serious dent and wonder how to start. In this case I started with this heavy dolly. I used every combination and angle of this thing to get up into the curve. Don't be afraid. Worse case, you end up cutting the panel off and replacing it. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif) Think out of the box. You can't alway swing a hammer up inside a tight panel. Sometimes you need a fist!
Here it is roughed in. I used the above dolly, and a couple other heavy blocks. Just because I call the tools heavy doesn't mean you abuse the panel. Lots of light blows spread out over the area while off hammering on the outside of the panel with help bring things around.
Here's the panel after about 3 solid hours of blocking, bumping and shrinking. I rough in the panel and then spray paint it. You can just dust a light coat of spray paint or use dykem if you have it. Then I use my bulleye pick and carefully and slowly work the low spots out as I check the panel with my body file. This photo is after I filed the panel then used a long board sander with a new sheet of 36 grit to check the panel. You can use the straight lines of the sander and check the panel with a light. The side panel was sanded with a 8" DA
There are still several pick hammer marks left in the panel from the last guy but I will work them out over the weekend and get them close. Like I said there will still be a fine glazing filler used to define the final shape. I think you'll all appreciate the final product.
scotty b
post Mar 4 2013, 10:35 PM
rust free you say ?
FWIW, and not ot steal Ricks thread, this 993 was done with only a dolly and a shrinking disc. Needed NO filler when done. Only a couple thick ( 3 ) coats of primer. Don't get suckerd into buying any expensive tools (IMG:style_emoticons/default/dry.gif)
http://kahikocustoms.com/auto-projects/993-collision-damage
rick 918-S
post Mar 5 2013, 07:44 AM
QUOTE(scotty b @ Mar 4 2013, 10:35 PM) *
Awesome work Scotty. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/first.gif)
Since my last post on this thread I purchased a shrinking disc. I am using on the Mercedes to finish the body seams after welding the panels. I'll have to take some photos and add it to my welding thread.
mrbubblehead
post Mar 5 2013, 12:04 PM
Twodollardoug
QUOTE(rick 918-S @ Mar 5 2013, 05:44 AM) *
how is the shrinking disc working for you rick? was there a learning curve?
rick 918-S   Here is a how to for dent removal Not just filling it up with plastic   Mar 1 2012, 10:01 PM
3d914   Awesome work Rick. Thanks for the insights. The d...   Mar 1 2012, 10:29 PM
rick 918-S   I'll add more about that later. Let me get a c...   Mar 1 2012, 10:33 PM
r_towle   I am just going to ship you my beatster.... I got ...   Mar 1 2012, 10:50 PM
rick 918-S   I am just going to ship you my beatster.... I got...   Mar 1 2012, 11:04 PM
Socalandy   Crazy mad skills sir!!! :worship: I...   Mar 1 2012, 10:52 PM
rick 918-S   Crazy mad skills sir!!! :worship: I...   Mar 1 2012, 11:04 PM
Tom_T   Rick, I haven't seen a panel master like you ...   Mar 1 2012, 11:10 PM
rick 918-S   Rick, I haven't seen a panel master like you...   Mar 2 2012, 12:37 AM
Tom_T   Rick, I haven't seen a panel master like yo...   Mar 2 2012, 04:13 AM
cary   Nice work.   Mar 2 2012, 12:05 AM
zymurgist   Very cool! :thumbsup:   Mar 2 2012, 05:57 AM
westtexass2k   Have you ever used a shrinking disc? I haven...   Mar 2 2012, 07:26 AM
rick 918-S   Have you ever used a shrinking disc? I haven...   Mar 2 2012, 08:28 AM
ruby914   Have you ever used a shrinking disc? I haven...   Mar 4 2012, 09:52 AM
Vacca Rabite   The same fender on my car was and is worse then th...   Mar 2 2012, 07:37 AM
majkos   :popcorn: Great thread, Rick. You make it look so...   Mar 2 2012, 08:50 AM
Jacob   Nice job Rick.   Mar 2 2012, 08:55 AM
worn   Nice job Rick. Really nice job Rick. Thank you ...   Mar 2 2012, 10:13 AM
Jacob   Nice job Rick.   Mar 2 2012, 10:08 AM
ww914   Nice work Rick. Looks like you've been reading...   Mar 2 2012, 10:15 AM
rick 918-S   Nice work Rick. Looks like you've been readin...   Mar 2 2012, 10:28 AM
andys   Nice work, Rick. The problem for an occasional me...   Mar 2 2012, 10:45 AM
rick 918-S   Nice work, Rick. The problem for an occasional m...   Mar 2 2012, 11:13 AM
bryanf   Beautiful work. I'm so glad that you ended up...   Mar 2 2012, 11:32 AM
beech4rd   Very, very impressive work. Thanks very much for ...   Mar 2 2012, 11:35 AM
watsonrx13   Excellent work Rick. Are you using a 15" or 2...   Mar 2 2012, 11:43 AM
maxwelj   Rick, Great work. I'll show this to my bodyma...   Mar 2 2012, 01:38 PM
Rand   Awesome work Rick. I love seeing things done right...   Mar 2 2012, 04:37 PM
gothspeed   Wow!!!!! :woohoo: .............   Mar 2 2012, 04:30 PM
westtexass2k   When I went to Ron Fornier class he talked about t...   Mar 2 2012, 06:22 PM
bobhasissues   Great work Rick. Please post a photo of your hamme...   Mar 2 2012, 08:11 PM
rick 918-S   I stripped the drivers door and found several Cali...   Mar 4 2012, 12:16 AM
RobW   You rock Rick! :headbanger:   Mar 4 2012, 07:59 AM
rick 918-S   I was kind of searching you tube for a good exampl...   Mar 4 2012, 10:57 AM
rick 918-S   Here's the result of several hours worth of wo...   Mar 4 2012, 08:56 PM
Eric_Shea   Rock on Rick! :trophy: One of my favorite col...   Mar 4 2012, 09:07 PM
rick 918-S   Rock on Rick! :trophy: One of my favorite co...   Mar 4 2012, 09:10 PM
scotty b   Awesome work as usual Rick :first: Get a shrinkin...   Mar 4 2012, 09:11 PM
rick 918-S   Awesome work as usual Rick :first: Get a shrinki...   Mar 4 2012, 09:13 PM
r_towle   Awesome and thank for taking my call. I will go ta...   Mar 4 2013, 07:11 PM
rick 918-S   Awesome and thank for taking my call. I will go t...   Mar 5 2013, 07:48 AM
scotty b   FWIW, and not ot steal Ricks thread, this 993 was ...   Mar 4 2013, 10:35 PM
rick 918-S   FWIW, and not ot steal Ricks thread, this 993 was...   Mar 5 2013, 07:44 AM
Spoke   Since my last post on this thread I purchased a s...   Mar 5 2013, 10:48 AM
scotty b   Since my last post on this thread I purchased a ...   Mar 5 2013, 12:14 PM
mrbubblehead   [quote name='scotty b' post='1829822' date='Mar 4...   Mar 5 2013, 12:04 PM
23 User(s) are reading this topic (23 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 08:02 PM
