mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
I'd like to know if anyone else with -6 linkage has seen this. The last
piece connected to the bar at the trans lever has 2 separate contacts/ movements, and even though I didn't see a wear pattern they were both pretty sloppy. Below I'll show what I did for this. The top channel contacts the ball of the trans lever. It has 18mils of slop in it but the ball doesn't look worn. I decided the easiest thing to do was glue in a 26-gauge brass shim with some 3M super90. Perfect fit now. Even if this wears within a year or two, it's very easy to re-do and I'm under the car a lot anyway. But the fork side of the piece has HUGE slop. About 75 mils. It actually looks like maybe somebody ground the opening wider because the casting is smooth and rounded everywhere else. So, this slop was taken basically to 0-5 mils by welding it and re-grinding. Sorry the pictures are only after being greased. It's still snowing here so I won't even get to feel for improvement for a while. Shim: ![]() Side view after welding: ![]() Rear view: ![]() |
Mr.242 |
May your glass be smaller so it's always FULL! ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest ![]() |
Interesting way to shim the gap. Wondering if it works... (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 24th June 2024 - 07:24 AM |
