> how do I save this? I removed it and hit it with acetone, my buddy the body shop dude painted this over
rgolia
post Mar 4 2013, 03:03 PM
GeoJoe
Any suggestions on how to save it or am I just screwed (IMG:style_emoticons/default/sheeplove.gif) ?Attached ImageAttached Image Well it looks like crap but better than painted over.
914GT
post Mar 7 2013, 10:32 AM
Definitely would want to score around the plate all the way down through the primer, otherwise it's going to pull all the new paint and probably the old paint off the door jamb when the plate is taken off.
rgalla9146
post Mar 8 2013, 08:18 AM
QUOTE(914GT @ Mar 7 2013, 08:32 AM) *
As already suggested, carefully cut around the edge with a razor.
Remove the speaker and push the rivets out from behind.
Replacements are available from Stoddard.
When the tag is in your hand you might even be able to peel the paint off.
Poor prep is in your favor. After that a plastic razor or plastic putty knife sounds good. But do it on a flat surface.
rgolia   how do I save this? I removed it and hit it with acetone   Mar 4 2013, 03:03 PM
SirAndy   Any suggestions on how to save it or am I just sc...   Mar 4 2013, 03:07 PM
r_towle   possibly tape and paint remover. It might work to ...   Mar 4 2013, 03:16 PM
MrKona   possibly tape and paint remover. It might work to...   Mar 4 2013, 04:16 PM
Kaduku   Dude that suck! That's why I rather pay a ...   Mar 4 2013, 03:17 PM
mrbubblehead   try goof off or graffiti remover. i have seen thre...   Mar 4 2013, 03:31 PM
balljoint   Finger nails.   Mar 4 2013, 03:32 PM
Kaduku   Finger nails. Great idea, but at the end, you m...   Mar 4 2013, 05:37 PM
Bartlett 914   I might be tempted to grind off the rivets and rem...   Mar 4 2013, 04:45 PM
Chris H.   I might be tempted to grind off the rivets and re...   Mar 7 2013, 08:28 AM
John1180   Don't use paint remover or solvents! The f...   Mar 4 2013, 04:51 PM
Tom_T   I used Acetone on Q-tips & carefully eased ...   Mar 4 2013, 05:32 PM
dpires914   I would try plastic razor blades like these http:...   Mar 4 2013, 05:51 PM
Cevan   No offense, but who the hell would paint right ove...   Mar 4 2013, 06:05 PM
rgolia   No offense, but who the hell would paint right ov...   Mar 7 2013, 07:15 AM
Kaduku   No offense, but who the hell would paint right o...   Mar 7 2013, 07:33 AM
bandjoey   Tape it off and wd40 and a soft brass dremm tool. ...   Mar 4 2013, 06:09 PM
ejm   Those are not rivets holding the plate on, they ar...   Mar 7 2013, 07:53 AM
Bartlett 914   Those are not rivets holding the plate on, they a...   Mar 7 2013, 10:25 AM
914GT   Definitely would want to score around the plate al...   Mar 7 2013, 10:32 AM
euro911   :agree: Definitely would want to score around th...   Mar 8 2013, 02:42 AM
gms   Karmann Numbers were not stamped into the -6   Mar 9 2013, 01:31 PM
rgalla9146   [size=2][b]Karmann Numbers were not stamped into ...   Mar 9 2013, 04:37 PM
rgalla9146   Definitely would want to score around the plate a...   Mar 8 2013, 08:18 AM
toadman   I have removed dried, overspray paint from chrome ...   Mar 7 2013, 11:03 AM
Cairo94507   Where does one find a new paint code plate like th...   Mar 8 2013, 07:59 AM
mepstein   Where does one find a new paint code plate like t...   Mar 8 2013, 08:22 AM
Socalandy   Where does one find a new paint code plate like t...   Mar 8 2013, 11:06 AM
Bartlett 914   Take it to a Porsche dealer and see it they can re...   Mar 8 2013, 01:53 PM
rjames   Wow. Hopefully he at least painted it the right ...   Mar 8 2013, 02:30 PM
Socalandy   If I could get more from my Germany contact what w...   Mar 8 2013, 03:36 PM
rgolia   If I could get more from my Germany contact what ...   Mar 8 2013, 04:37 PM
rgolia   If I could get more from my Germany contact what...   Mar 8 2013, 04:47 PM
pete000   Wow did not know the pins were not rivets! M...   Mar 8 2013, 03:38 PM
pete000   If I could get more from my Germany contact what ...   Mar 8 2013, 03:39 PM
ejm   The parts catalog lists a "badge for lacque...   Mar 8 2013, 05:04 PM
rgolia   well I got it off and hit it with acetone....this ...   Mar 20 2013, 04:40 PM
- Lo-Fi Version Time is now: 27th December 2024 - 04:14 PM
