> Shrinkage ?
cary
post Mar 12 2013, 01:34 PM
We're getting ready to move the project off the rotissere to the lift.
We'd rehung the doors . Pretty scary hanging there on the rotissere.
How many 100's should we allow for shrinkage when we reinstall the long?
cary
post Mar 12 2013, 09:02 PM
Here's the pictures I promised.
Put the doors back on to make sure everything is perfect.
Might need some adjustment. This is where I ended up even with the door brace installed in the beginning.
But this is with the drivers long removed.
Passenger side.
post Mar 12 2013, 09:06 PM
Resident German
QUOTE(cary @ Mar 12 2013, 08:02 PM) *
Passenger side.
Not even close. It looks like you could use some shrinkage! (IMG:style_emoticons/default/biggrin.gif)
I think you need adjustable braces that allow you to pull or push the car until everything lines up.
http://www.914world.com/specs/bodydims.php
http://www.914world.com/specs/underdims.php
cary   Shrinkage ?   Mar 12 2013, 01:34 PM
rick 918-S   Shrinkage is not required or desired. :ttiwwp:   Mar 12 2013, 04:32 PM
cary   Took lots of pictures on my camera that l'll p...   Mar 12 2013, 05:28 PM
scotty b   Weld slowly, mocve around, not in one direction, a...   Mar 12 2013, 08:20 PM
cary   Here's the pictures I promised. Put the doo...   Mar 12 2013, 09:02 PM
SirAndy   This is where I ended up even with the door brace ...   Mar 12 2013, 09:06 PM
cary   Moving from the rostissere to the lift. The ...   Mar 12 2013, 09:09 PM
cary   Almost getting there on the passenger side. But...   Mar 12 2013, 09:16 PM
cary   Here's the drivers side.   Mar 12 2013, 09:18 PM
cary   I do have adjustable door braces. I can move the d...   Mar 12 2013, 10:18 PM
cary   Got up early to finish reading this post. http://w...   Mar 13 2013, 07:28 AM
SirAndy   I'm just seeking perfection on a tub that most...   Mar 13 2013, 11:25 AM
ThePaintedMan   While the door gaps are important and visually an...   Mar 13 2013, 11:42 AM
sixnotfour   Better measure the windshield to targa bar also, T...   Mar 13 2013, 12:11 PM
cary   Time for lunch. Feel much better now. Both doors ...   Mar 13 2013, 02:42 PM
cary   Here's the pictures from today. Drivers s...   Mar 13 2013, 10:07 PM
cary   Here's the suspension point jig we built. Bolt...   Mar 13 2013, 10:12 PM
cary   Tomorrow we'll install the drivers long after ...   Mar 13 2013, 10:25 PM
rick 918-S   get the drivers door gap closed up around 5mm max...   Mar 13 2013, 11:37 PM
Jeff Hail   There is a lot of good feedback and direction here...   Mar 14 2013, 01:33 AM
cary   After seeing how much the front 1/2's can move...   Mar 14 2013, 09:30 AM
mskala   ... I do believe we'll create some sort of br...   Mar 15 2013, 12:01 PM
cary   It didn't happen. We're still tinkering. S...   Mar 15 2013, 08:57 AM
cary   Got tired of nicking the paint (whats left of it) ...   Mar 15 2013, 08:59 AM
cary   Here's the body supported on the lift.   Mar 15 2013, 09:01 AM
cary   Here's the measurement tools I created for mea...   Mar 15 2013, 09:03 AM
SirAndy   I think you're doing good. Can't wait to s...   Mar 15 2013, 11:21 AM
3d914   That's a very challenging restoration. Impress...   Mar 15 2013, 01:28 PM
cary   Its really more about the tub flexing when you f...   Mar 15 2013, 02:30 PM
worn   Its really more about the tub flexing when you ...   Mar 19 2013, 10:46 AM
cary   I've already crushed one. When they're gon...   Mar 19 2013, 09:29 PM
cary   Here's the door gap measurement rods in use. ...   Mar 20 2013, 10:05 PM
cary   Here's the door gap measurement rods in use. ...   Mar 24 2013, 08:58 AM
cary   The long is finally installed. :D The car is ...   Mar 20 2013, 10:16 PM
cary   Body movement nBDTWFJWX3I That was easy   Mar 20 2013, 11:27 PM
- Lo-Fi Version Time is now: 27th December 2024 - 09:36 PM
