> LS1 Conversion, A Retrospective Build Thread
andys
post Feb 21 2013, 12:43 PM
Here's the start of a retrospective build thread of my LS1 conversion. It took a few years to get it done mostly due to not wanting to be a slave to the project, and work on it for the enjoyment; and of course when family obligations allowed......teen daughter and high maintenance wife (IMG:style_emoticons/default/biggrin.gif)
What I started with was a local orignal owner '75 2.0 with 139K miles. The original owner "drove the heck out of it" until something died in the electrical system and he parked it in the garage for 14 years, as evidenced by the renewal tags. Only body damage was when he submarined the rear of a Mustang and creased the hood and flattened the left signal light pod. Otherwise, it was a good condition rust free (SoCal) car.
Brief specs are: '01 LS1 Z28 motor, Audi 01E 6 speed tranaxle, 911 front suspension, custom made rear trailing arms, Koni shocks, 993 wheels, and AC.
Below, are photos of what I started with, and what I ended-up with. I'll do my best to re-trace the build process, so if you have any questions along the way, please ask.
BTW, how does one place text between photos in the same post?
Andys
andys
post Mar 13 2013, 12:16 PM
As the cooling system is a crucial part of a V8 conversion, I wanted to be sure to apply good practices for both performance and reliability. I first set out to configure the layout. As such, I decided on thru hood venting rather than the traditional thru fender venting. What I don't care much for with the thru fender venting, is that it creates a big under hood hot box. The thru hood venting, with appropriate ducting, allows the heat to rise naturally thru the opening which is especially important when sitting still in traffic. Down side of thru hood venting is of course it's affect on the car's styling. Enough pontification; lets build a cooling system!
I started with an aluminum radiator from AFCO; P/N 80133N which is an ASA racing radiator, dual pass, cap delete, 27 1/2 x 16 x 3. I see now that Summit sells them, though it's about $100.00 more than I paid a few years ago when I bought directly from AFCO. I'm going to gush a bit about how great these guys at AFCO are to deal with. Again, your typical Mid-Western stock car supplier/manufacturer that is a joy to work with...great attitude, etc. Anyway, the radiator size works out well in the 914; all that was needed was to tip it slightly forward, and it fit.
First I cut an opening in the front bulkhead, and re-enforced the center rib with a formed piece of channel to help stiffen the structure. I then determined the most suitable position for the radiator and went about designing a mounting scheme. I did what I've done on race cars, which is to build a U shaped channel lined with foam into which the radiator gets inserted into. This avoids any hard mounting, and completely shock mounts and isolates the radiator. I always cringe when I see folks hard mount radiators. There are of course other ways to shock mount, but this is how I like to do it. I made the U shaped channel out of aluminum with tabs in strategic locations for mounting. For the mounting points, I also shock mounted this structure to the chassis with two rubber isolators on the bottom, and two rubbber grommet mounts on the top. I used two Zirgo 10" puller fans and mounted them to a shroud. I also made some silicone rubber flaps to pass additional air at higher speeds thru the shroud as well. The shroud bolts to the structure.
For the ducting, I made some sheet aluminum ducts both front and back that mount to the radiator U structure, but do not fasten to the bulkhead, but stop short with foam gasketing to make the final seal. For the exit side, I made a duct that turns upwards. A foam gasket seals the gap between it and the hood.
The hood vent piece (diffuser) was designed with the help of an Art Center College of Design student, as I have no styling talent what so ever. I made a foam model which I covered with fiberglass and filled and sanded smooth. The size of the opening in the hood is 1.7 times the inlet side to help create the requisite pressure differential to draw the air out (with the help of the vent/diffuser). This diffuser sandwiches a rubber gasket to protect the paint, and is fastened to the hood by stailness button head screws from the underside (I bonded threaded inserts into the diffuser). With all this however, like very much what byndbad914 did with the louvered diffuser on his track car. Looks racey and subtle; if I would have known at the time, I would have simply gone that route instead.
I'll get to the piping in the next post.
andys   LS1 Conversion   Feb 21 2013, 12:43 PM
Tom_T   In Full Edit mode - just add space lines with your...   Feb 21 2013, 12:55 PM
andys   In Full Edit mode - just add space lines with you...   Feb 21 2013, 01:16 PM
worn   In Full Edit mode - just add space lines with yo...   Feb 21 2013, 02:07 PM
andys   I decided quite quickly, that I wanted to go with ...   Feb 21 2013, 01:11 PM
andys   I wanted to avoid having a motor shipped, so I sta...   Feb 21 2013, 02:34 PM
andys   I wanted to start by adapting the motor to the tra...   Feb 21 2013, 05:48 PM
Bruce Hinds   Tell us about that jack!   Feb 21 2013, 06:33 PM
andys   Tell us about that jack! Bruce, I spend 6 ...   Feb 21 2013, 06:47 PM
turk22   Lovin this story and the work you did. Looking fo...   Feb 21 2013, 07:25 PM
Bruce Hinds   ask about the jack! Well yeah... the cars fre...   Feb 21 2013, 07:47 PM
andys   ask about the jack! Well yeah... the cars fr...   Feb 22 2013, 10:27 AM
kg6dxn   Keep going! We need more! I know you did ...   Feb 21 2013, 07:47 PM
andys   With the motor and transaxle coupled together, I n...   Feb 22 2013, 12:32 PM
TurboWalt   Great work, keep the pics coming!   Feb 22 2013, 02:15 PM
BIGKAT_83   Great work! keep the pictures coming. I keep c...   Feb 22 2013, 02:29 PM
andys   While not exactly in the correct sequence of the b...   Feb 22 2013, 03:07 PM
worn   Amazing. Inspiring. I wanna drive it!   Feb 22 2013, 09:52 PM
rick 918-S   :beer2: :welder: :sawzall: :smash: :headbanger...   Feb 23 2013, 07:39 AM
Cairo94507   I am in awe. Amazing skills and work. Keep ...   Feb 23 2013, 08:03 AM
jersey914   Cool conversion, way out of my league   Feb 23 2013, 08:54 AM
Bruce Hinds   Holy smokes, you're a handy guy to have around...   Feb 24 2013, 10:16 AM
andys   I mentioned earlier the need to move the firewall ...   Feb 24 2013, 12:01 PM
messix   have you left the tranny in the original location ...   Feb 24 2013, 12:14 PM
andys   have you left the tranny in the original location...   Feb 24 2013, 12:16 PM
messix   have you left the tranny in the original locatio...   Feb 24 2013, 12:24 PM
andys   Determining where the engine/transaxle assembly wo...   Feb 24 2013, 05:32 PM
Krieger   I like your work! Weight wise you better off w...   Feb 24 2013, 07:16 PM
andys   The 01E transaxle flanges are a tripoid design whi...   Feb 26 2013, 03:30 PM
charliew   great work. I also like the jack. I missed the par...   Feb 26 2013, 05:26 PM
andys   great work. I also like the jack. I missed the pa...   Feb 26 2013, 06:34 PM
andys   So we've got the motor/transaxle mounted, and ...   Feb 27 2013, 06:35 PM
slothness   :worship:   Feb 27 2013, 06:40 PM
trojanhorsepower   wow........ that is impressive   Feb 27 2013, 06:45 PM
bigkensteele   You, my friend, are insane! Incredible work...   Feb 27 2013, 10:46 PM
Bruce Hinds   Holy mother of God! I thought the Jack was a ...   Feb 27 2013, 11:08 PM
andys   Thanks for all the nice words! A couple more ...   Feb 28 2013, 12:04 PM
get off my lawn   What color is that jack, fire engine red? j/k ...   Feb 28 2013, 04:34 PM
andys   I re-enforced the inner suspension ears with a sor...   Mar 4 2013, 02:33 PM
JRust   You really should have just made 2 of everything :...   Mar 4 2013, 02:41 PM
andys   Let's install the Engman chassis stiffening ki...   Mar 7 2013, 12:49 PM
jd74914   I don't own a MIG welder, so TIG was my only ...   Mar 7 2013, 06:40 PM
andys   You need a thumb control Andy. They are perfect ...   Mar 8 2013, 10:25 AM
andys   I forgot to mention, that I put a few Tek screws o...   Mar 7 2013, 01:03 PM
andys   I installed fiberglass flares, and here's why....   Mar 12 2013, 02:07 PM
andys   As the cooling system is a crucial part of a V8 co...   Mar 13 2013, 12:16 PM
quadracerx   WOW... Nice work!! Has anyone tried a ...   Mar 13 2013, 01:45 PM
SouthCali914   WOW... Nice work!! Has anyone tried a ...   Mar 14 2013, 12:43 AM
andys   As promised, here's what I did with the radiat...   Mar 14 2013, 01:47 PM
andys   I found a couple of more photos (with the exit duc...   Mar 14 2013, 04:44 PM
tscrihfield   Andy, this has shown a lot of great, quality work...   Mar 14 2013, 09:42 PM
andys   I stubled across a couple more coolant pipe photos...   Mar 16 2013, 09:37 PM
andys   Here's how I did my shift linkage. I know that...   Mar 20 2013, 12:26 PM
andys   Time to get back to posting more retrospective bui...   Mar 26 2013, 02:08 PM
andys   Thought I'd go through the fuel system next. T...   Mar 28 2013, 03:28 PM
dflesburg   Wow, amazing work, the only comment I have is why ...   Mar 29 2013, 09:08 AM
andys   The AA steel flares were not yet available at the ...   Mar 29 2013, 09:17 AM
DBCooper   Looks excellent, and like a whole lot of fun. I p...   Mar 29 2013, 09:30 AM
andys   Looks excellent, and like a whole lot of fun. I ...   Mar 29 2013, 10:10 AM
DBCooper   I'm not worried about explaining anything to m...   Mar 29 2013, 04:28 PM
Rand   But if you have that thing out somewhere and some ...   Mar 29 2013, 10:42 AM
dfelz   Great build Andy, your work is top notch and looks...   Mar 29 2013, 01:09 PM
andys   Great build Andy, your work is top notch and look...   Mar 29 2013, 01:41 PM
dfelz   Awesome, thanks! I love McMaster, they have ev...   Mar 29 2013, 02:28 PM
andys   Awesome, thanks! I love McMaster, they have e...   Mar 29 2013, 02:49 PM
dfelz   Awesome, thanks! I love McMaster, they have ...   Mar 29 2013, 04:35 PM
andys   [quote name='andys' post='1842361' date='Mar 29 2...   Mar 30 2013, 08:40 PM
dfelz   [quote name='andys' post='1842361' date='Mar 29 ...   Mar 31 2013, 11:38 AM
914GT   Andys I've been following your build thread f...   Mar 29 2013, 06:18 PM
andys   Andys I've been following your build thread ...   Mar 30 2013, 08:59 PM
kg6dxn   I nominate this thread for the Classics. It will ...   Mar 31 2013, 11:58 AM
BIGKAT_83   :agree: Andy has set a new standard for everyone...   Mar 31 2013, 12:33 PM
andys   I'm jumping around a bit, however lets go ahea...   Apr 5 2013, 07:19 PM
andys   Thought I'd take y'all through the AC syst...   Apr 11 2013, 12:20 PM
drive-ability   Andy, That car looks fantastic ! My la...   Oct 7 2013, 11:26 PM
andys   Andy, That car looks fantastic ! My l...   Oct 8 2013, 01:45 PM
914forme   Okay, I know your not to it in your story but I kn...   Oct 8 2013, 06:35 PM
914forme   double post- sorry   Oct 8 2013, 06:35 PM
andys   Okay, I know your not to it in your story but I k...   Oct 9 2013, 10:10 AM
914forme   Thank you sir that is absolutely brilliant, and I ...   Oct 9 2013, 01:00 PM
Mueller   wow, just wow....great build...after seeing such i...   Jan 18 2015, 11:54 AM
drive-ability   I want you on my team !!!!!...   Jan 18 2015, 05:17 PM
Maltese Falcon   Just read through your thread with great enthusias...   Jan 18 2015, 08:42 PM
andys   Just read through your thread with great enthusia...   Jan 19 2015, 10:41 AM
Maltese Falcon   Just read through your thread with great enthusi...   Jan 19 2015, 08:40 PM
mgp4591   Thanks for the link Andy- got me inspired to work ...   Jan 18 2015, 09:28 PM
andys   Thanks for the link Andy- got me inspired to work...   Jan 19 2015, 10:47 AM
JRust   Thanks for the link Andy- got me inspired to wor...   Jan 19 2015, 11:47 AM
andys   [quote name='andys' post='2135997' date='Jan 19 2...   Jan 19 2015, 12:17 PM
JRust   Jamie, Thanks for the heads-up. March is a maybe...   Jan 19 2015, 04:22 PM
Mueller   Are you doing your own plating on the small steel ...   Jan 19 2015, 04:39 PM
andys   Are you doing your own plating on the small steel...   Jan 20 2015, 11:04 AM
Rand   I just hope those who poopoo this conversion find ...   Jan 19 2015, 09:57 PM
drive-ability   That is one nice car, great craftsmanship bumper ...   Mar 26 2015, 11:18 PM
Mueller   Anything new to show us on this cool build? :)   Aug 11 2017, 02:58 PM
andys   Well, the car is done, but then again, they are ne...   Aug 11 2017, 03:38 PM
whitetwinturbo   :popcorn: :popcorn: :popcorn: .........lurking i...   Aug 27 2017, 10:33 PM
- Lo-Fi Version Time is now: 20th April 2025 - 03:46 AM
