getting more defined on the noise coming from my engine/tranny |
jdlmodelt |
Mar 6 2013, 07:02 AM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
Okay...so this noise coming from the engine/tranny compartment is a repetitive almost squeaking sound at higher speeds but a rattling sound at low speeds. It's frequency is in direct relationship to the speed of the vehicle. It only occurs when the car is in gear. It is less prevalent almost in audible when the engine is under load. It is most audible when the car is coasting in gear, any gear and even more so when the car is traversing a right hand curve. If I take the car out of gear and coast there is no noise at all. I'm suspecting it is a noisy differential? Doc?
Jeffs9146 |
Mar 14 2013, 12:58 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
You can convert the tail shift to a side shift using the parts from the side shift and work on the side shift while you drive and repair!! (IMG:style_emoticons/default/piratenanner.gif)
jdlmodelt |
Mar 14 2013, 01:01 PM
You can convert the tail shift to a side shift using the parts from the side shift and work on the side shift while you drive and repair!! (IMG:style_emoticons/default/piratenanner.gif) Is there a link that explains and shows me how to convert? j |
Lo-Fi Version | Time is now: 26th September 2024 - 05:29 PM |
