center console |
center console |
johnpierre |
Mar 14 2013, 11:06 AM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
i have a couple of quick questions for you all. the center console that houses the 3 gauges-was it the same for all years. meaning did it change from one year to another or were there two different types/styles, etc. or was it the same for all years?
and two is it relatively simple to i wire up the three gauges to my 73 that didn't come with the console originally? there is one for sale and i want to move on it asap? i read in my new 914 book (thanks porsche dreamer) that in 73 you could of had it as an option. well i want to add it as an option now (only 40 years late, no big) ha ha. jp |
Tom_T |
Mar 14 2013, 03:49 PM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
jp - there was only 1 style non-AC console & 2 AC styles for VPC & DPD AC dealer options. There is some good equipment by MY info at p914.com
PS edit - there were 2 different OT gauges used - 73 with a wider red band & 74-76 with a narrow one, & IIRC they used different senders at the engine too. IIRC the dealers cut your console sides & used either the VPC or DPD supplied short 3-gauge face. The other 2 would only matter if you have AC (see pix below if your do). Your 914 isn't in the data base, so I can't tell which MY you have, but ray harvey & the others above are correct that 73-76 had the harness leads & quick-connect clip for the harness. If not, you'll need to get the wiring diagram & some help to figure out which to cut into for the harness & hard wired them in using a quick-connect & short pig-tail, so you can easily disconnect it again for any interior or tunnel work, etc. (& not have to cut wires). If the one you buy doesn't have the console's sub-harness, then I think Jeff Bowlsby makes them or can do so. DPD AC short console w/ inline angled gauges & AC controls above inline w/ console below - . VPC AC short console w/ triangular pattern flat gauges & AC gauges above offset to right of console below - . Good Luck! (IMG:style_emoticons/default/beerchug.gif) |
type47 |
Mar 15 2013, 06:40 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
...- there were 2 different OT gauges used - 73 with a wider red band & 74-76 with a narrow one, & IIRC they used different senders at the engine too. ..., you'll need to get the wiring diagram & some help to figure out which to cut into for the harness & hard wired them in using a quick-connect & short pig-tail, so you can easily disconnect it again for any interior or tunnel work, etc. (& not have to cut wires). If the one you buy doesn't have the console's sub-harness, then I think Jeff Bowlsby makes them or can do so. I think the console wiring is about tracks 51-63-ish in the schematic below |
Lo-Fi Version | Time is now: 27th December 2024 - 04:21 PM |
