CV joint bolt torque., Re-torqued the next day. |
Elliot Cannon |
Mar 16 2013, 02:48 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I guess this goes under the "for what it's worth" collumn but I recently bolted up my inner CV joints. I used gaskets and torqued them down. I waited till the next day to safety wire them and decided to re-torque them. Each bolt turned an additional 1/8 to 1/4 turn. Some of you might already use this tightening technique but I thought I'd post it anyway. For what it's worth. (IMG:style_emoticons/default/biggrin.gif)
bandjoey |
Mar 16 2013, 09:38 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
The dumb question of the day then...
Why did the factory give a torque setting with a gasket?? Did they intend for you to re-torque after a break in period? (IMG:style_emoticons/default/confused24.gif) Do U use the same torque without the gasket? Thanks for the info. |
Lo-Fi Version | Time is now: 14th January 2025 - 05:50 PM |
