Rear trailing arm bushing removal? |
SKL1 |
Mar 16 2013, 08:35 PM
Senior Member Group: Members Posts: 1,646 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Search wasn't too helpful. Rebuilding rear 914-6 trailing arms with new bearings, bushings etc
Best way to remove the 42+ year old rear bushings? Front A-arm bushings came off reasonably well with heat and wrestling... TIA If someone has a link to an old thread that would be great as I couldn't find one. |
Jeffs9146 |
Mar 17 2013, 10:02 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
No need to spend $99!!!
Clamp the arm in a vice, heat the end bracket with a torch until a small bit of smoke starts to flow and use a screw driver to twist the bracket off!! (IMG:style_emoticons/default/beerchug.gif) |
Eric_Shea |
Mar 17 2013, 12:10 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
No need to spend $99!!! Clamp the arm in a vice, heat the end bracket with a torch until a small bit of smoke starts to flow and use a screw driver to twist the bracket off!! (IMG:style_emoticons/default/beerchug.gif) He's talking about the "rear" bushings. Fronts come out with your method and a simple large screwdriver. 10 years later the simple press is still working and paying for itself over and over again, however, I don't think they're $99 anymore. If you have a big coupon deal they may be close though. Regardless, well worth it. |
Lo-Fi Version | Time is now: 27th December 2024 - 08:26 PM |
