Aspect ratio for my new tires |
Harpo |
Mar 19 2013, 04:30 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I have a set of 6x16 for the front and 7x16 for the rear. Because of the different widths the same tire will be .8 inch different front to rear. Does anyone have any experience with this?
The tires that I want to buy are the Yokohama s drive and in the 205 tire size They have both 50 & 55 aspect ratios. Some advise would be appreciated Thanks David |
ChrisFoley |
Mar 20 2013, 05:37 PM
I am Tangerine Racing Group: Members Posts: 7,968 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
If you have stock fenders forget about 225s. Even 215s would probably require pulling the fenders a little bit.
IMO it would be smarter to use the exact same tire rather than a lower aspect tire in the rear. If I was doing that I would use the same width rim. Not saying you shouldn't do it, just that I would look for two 6s or 7s to make a matched set. |
Lo-Fi Version | Time is now: 27th December 2024 - 02:29 PM |
