Introducing myself, introduction |
SouthCali914 |
Feb 14 2013, 03:28 PM
Newbie Group: Members Posts: 25 Joined: 1-January 13 From: North San Diego county Member No.: 15,320 Region Association: None |
Hello all,
Finally was able to register my account so I thought I would introduce myself. My name is Geoffrey & my recent acquisition of a 74 1.8 914 would be the reason for joining the group. I got an awesome deal on my not too rusty little gem, paid a thousand bucks. she's completely stock but for wheels (empi eight spokes) stereo, electronic ignition & an addco type front swaybar. thus far I have brought all the maintenance up to date with a valve adjustment, plugs, filters... I also was getting some noise out of the wheel brgs so I replaced them all. I also replaced the dry rotted pizza cutter tires with new 195/60/15's & dropped the front ride height to get rid of the nose in the air look. next up is saving the car. I.E. fixing the rust. In this regard I feel I got pretty lucky. small amounts of surface rust here and there with the worst of it being spots under the rocker panels at the jacking points, under the passenger side headlamp & at the lower firewall on the drivers side. right now she's what I call a rolling resto. I'm currently d/d her while I finish the restafication of my 91 Galant VR4. One the Galant is finished, hopefully in the next six months or so, the teener will go under the knife. right now I'm leaning towards the wrx swap but having a good friend working in a local VW shop I may let him talk me into a 2056 build... jury is still out. About me; I have been a car guy/mechanic for about 25 years. I have restored & modified more cars than I can count for myself, my friends & my customers. I look forward to being an active member of the 914 community & look forward to meeting some of you guys & seeing your projects first hand. I live in Fallbrook, located in north San Diego county CA. so if you happen to see my little white, for now, Beater, feel free to say hello. so far I have only seen a couple others on the road. one really nice guy with a nice orange 2.0 & another white one running around Escondido with a trunk rack. Peace, Geoffrey. "Joffrey" |
Gint |
Mar 20 2013, 07:00 PM
Mike Ginter Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Hey, in another thread you wrote:
Ok, got mine figured out & fixed. The starter solenoid just wants more amps than are making from the bat to the ignition & back to the starter. I had removed & cleaned all my grounds, all of them! Hiding all over the damn place (IMG:style_emoticons/default/headbang.gif) Checked for voltage drop to the ignition switch & back at the solenoid. The solenoid from time to time wants more amps than that circuit will give it for size & length. So I added a relay. Put it right next to the starter. About six inches of heavy gauge wire from the main starter bat+ lug & again back to the solenoid. ran the ground to the solenoid mounting screw & energize it with the original solenoid wire. It has cranked over much better at all times now & happy to report Zero no-crank issues. Took far longer to diag than to repair. To sum up. if you have a random no-crank pull the solenoid wire & see if it will light up a good test light. if it will then add a relay & call it fixed. If not you have my sympathy, it's not a fun circuit to trace. Upside I learned how to rebuild my underhood relay block. now my voltage always stays above 12. (IMG:style_emoticons/default/beerchug.gif) Exactly how did you wire that relay/solenoid/starter? Sounds different than the way mine is setup. I'll send you a PM. |
Lo-Fi Version | Time is now: 28th December 2024 - 01:01 AM |
