> Red rear reflector And trunk release, See pic
jim_hoyland
post Mar 22 2013, 05:22 PM
Get that VIN ?
Do you mount the trunk release switch next to the engine lid pull ? If so, how long a switch is needed to go through the fire wall and backpad ? Seems like there are better places to put it- what do you have ?
And, how is the emergency pull wire mounted to the solenoid? I don't see a place where there is going to be sufficient leverage
(IMG:http://www.914world.com/bbs2/uploads_offsite/i721.photobucket.com-643-1364056945.1.jpg)
pcar916
post Mar 22 2013, 06:16 PM
Is that a Lola?
This is an electrical switch right? Why wouldn't you mount it anywhere you like? The backup pull is mechanically attached isn't it? I haven't ever seen any of these.
jim_hoyland   Red rear reflector And trunk release   Mar 22 2013, 05:22 PM
914itis   When I had mine, it was under the arm rest mounted...   Mar 22 2013, 05:30 PM
JamesM   mine is under the dash near the fuse panel   Mar 22 2013, 05:53 PM
pcar916   This is an electrical switch right? Why wouldn...   Mar 22 2013, 06:16 PM
PanelBilly   Years ago when I had one of these I added a solid ...   Mar 22 2013, 06:30 PM
struckn   Mine is to the right and above the rear Tag on the...   Mar 22 2013, 06:52 PM
ruby914   Mine is to the right and above the rear Tag on th...   Mar 24 2013, 12:13 AM
injunmort   mine is mounted under dash right next to the fuse ...   Mar 22 2013, 07:02 PM
Jeffs9146   Mine is mounted in the corner of the fuse panel...   Mar 22 2013, 07:08 PM
injunmort   mine is in the same spot on the other side of the ...   Mar 22 2013, 07:13 PM
Jeffs9146   mine is in the same spot on the other side of the...   Mar 22 2013, 07:18 PM
kg6dxn   On my old 914, it was mounted into the glove box. ...   Mar 22 2013, 07:23 PM
jim_hoyland   My second question is How do I attach the emergenc...   Mar 23 2013, 09:14 AM
kg6dxn   My second question is How do I attach the emergen...   Mar 23 2013, 09:38 AM
Maltese Falcon   I mount the safety pull wire to the fulcrum point ...   Mar 23 2013, 09:57 AM
jim_hoyland   I mount the safety pull wire to the fulcrum point...   Mar 23 2013, 06:40 PM
Vacca Rabite   Of course, unless you need to lock your trunk, you...   Mar 23 2013, 10:14 AM
jim_hoyland   Pictures coming: http://www.914world.com/bbs2/upl...   Mar 23 2013, 10:29 AM
kg6dxn   If it were mine... I would weld a bracket... Like ...   Mar 23 2013, 04:34 PM
Jeffs9146   Here is how I did mine on my 74! It has a han...   Mar 23 2013, 04:41 PM
jim_hoyland   Jeff - Did you make any mods to the solenoid ? Loo...   Mar 23 2013, 06:31 PM
Jeffs9146   Yes I made another pin that holds the pivot arm to...   Mar 23 2013, 06:51 PM
jim_hoyland   Yes I made another pin that holds the pivot arm t...   Mar 23 2013, 08:05 PM
Jeffs9146   Yes I made another pin that holds the pivot arm ...   Mar 24 2013, 03:03 PM
Steve Snyder   I used an extra fog light switch with a blanked-ou...   Mar 24 2013, 07:26 AM
rdauenhauer   Mine is in a nearby lake, along with the rest of t...   Mar 24 2013, 12:36 PM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 03:54 AM
