doug_b_928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 694 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada ![]() |
I'm sorry if this is a silly question/topic. I'm still in the researching stage for my restoration. I was at the local autobody supply store yesterday and was asking them about spraying epoxy primer with a gun vs. using etching primer in a rattle can. I don't have a gun and have never used one. I know Jeff Hail's thread says to spray epoxy primer after each area is repaired. They said that either way (i.e., even with a rattle can) there is an issue with overspray. I don't have a dedicated shop and there is literally no place at my house where I would want overspray. They told me a story about overspray going hundreds of feet. So, I was thinking that what I could do is have a tarp on the concrete under the car (plan is to make a bench a la Hail) and drape a poly tarp over the car. I can't tape poly to the ceiling to make a pseudo paint booth because the garage door would hit it when it's open. I suppose I could make a makeshift poly tent that fits under the garage door. But, I would think that lack of ventilation would be a big problem. Would this work? Be too unsafe? Better to rent a workspace and do all the metal work/priming elsewhere? Your thoughts and experiences would be helpful.
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,824 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Don't worry so mu h about overspray. Tape off areas near to where your spraying and go for it. The little overspray on the farther areas will be paint that is nearly dry and you can clean it off later
Lo-Fi Version | Time is now: 26th June 2024 - 10:06 AM |
