Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
A great part to have if you need one. I was tapped to make these awhile ago, and there looked like there was some interest in doing these. I plan to make them from silicone of a soft enough durometer to allow them to stretch easily. The flanges will be slightly larger to allow for a tighter fit. So there will be some improvements, but look pretty stock. They should be easier to install than stock. I try to make most of my stuff as close to factory as possible where it makes sense, and I think factory had it right as one piece.
Attached thumbnail(s) ![]() ![]() |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
A great part to have if you need one. I was tapped to make these awhile ago, and there looked like there was some interest in doing these. I plan to make them from silicone of a soft enough durometer to allow them to stretch easily. The flanges will be slightly larger to allow for a tighter fit. So there will be some improvements, but look pretty stock. They should be easier to install than stock. I try to make most of my stuff as close to factory as possible where it makes sense, and I think factory had it right as one piece. In for 2. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:35 AM |
