Front steering eye-bolt, installation question |
dawg |
Mar 24 2013, 01:10 PM
Newbie Group: Members Posts: 16 Joined: 23-March 13 From: New Jersey Member No.: 15,685 Region Association: None |
I read that the tie rod eye-bolt end (that goes into the steering rod) needs to be installed / aligned with a special tool or else....
I removed the old eye-bolt (right side) with steering still in car. I noted the position of the eye-bolt. It was pointed towards the rear. That said, I really don't see much else that makes it so "special". SO.... I put the new eye-bolt in, in about the same position and made sure the "lean" is towards the back. What I noticed when I took the old eye-bolt out, it was really hard to remove. What I notice now is that when I put the eye-bolt in, and connect the tie rod fork end, the eye bolt can easily be turned by hand - in either direction. There is a metal cap on the eye-bolt that the bellows connects to. Is that the piece that needs to put the tourque on that eye-bolt, or am I totally hosed at this point? |
914Sixer |
Mar 24 2013, 05:19 PM
914 Guru Group: Members Posts: 9,043 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Porsche had a special jig that the racks fit in. Eye bolts have to be canted at about 8 (?) degrees. If the eye bolt is NOT at the proper angle, the steering rack will bind. Yes, the metal cap has to be in place to act as a spacer.
dawg |
Mar 24 2013, 05:46 PM
Porsche had a special jig that the racks fit in. Eye bolts have to be canted at about 8 (?) degrees. If the eye bolt is NOT at the proper angle, the steering rack will bind. Yes, the metal cap has to be in place to act as a spacer. The eye-bolt is already canted. The angle points toward the rear of the car. What I don't understand is what holds the eye-bolt in that position. The cap acting as a lock nut? |
JFJ914 |
Mar 24 2013, 05:50 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Porsche had a special jig that the racks fit in. Eye bolts have to be canted at about 8 (?) degrees. If the eye bolt is NOT at the proper angle, the steering rack will bind. Yes, the metal cap has to be in place to act as a spacer. The eye-bolt is already canted. The angle points toward the rear of the car. What I don't understand is what holds the eye-bolt in that position. The cap acting as a lock nut? Yes. Didn't you loosen it to remove the eyebolt? |
dawg |
Mar 24 2013, 05:55 PM
Porsche had a special jig that the racks fit in. Eye bolts have to be canted at about 8 (?) degrees. If the eye bolt is NOT at the proper angle, the steering rack will bind. Yes, the metal cap has to be in place to act as a spacer. The eye-bolt is already canted. The angle points toward the rear of the car. What I don't understand is what holds the eye-bolt in that position. The cap acting as a lock nut? Yes. Didn't you loosen it to remove the eyebolt? Not really.... I removed the eye-bolt with the steering still mounted on the car. I just took it off untill it came free of the inside bar - the cap still attached, then unscrewed the rest from the cap. Is there a hex bolt welded to the inside of that cap that I need to use to make it hold the eye-bolt in place? If not, how do you get the cap and eye-bolt tightened together? |
JFJ914 |
Mar 25 2013, 03:04 PM
Porsche had a special jig that the racks fit in. Eye bolts have to be canted at about 8 (?) degrees. If the eye bolt is NOT at the proper angle, the steering rack will bind. Yes, the metal cap has to be in place to act as a spacer. The eye-bolt is already canted. The angle points toward the rear of the car. What I don't understand is what holds the eye-bolt in that position. The cap acting as a lock nut? Yes. Didn't you loosen it to remove the eyebolt? Not really.... I removed the eye-bolt with the steering still mounted on the car. I just took it off untill it came free of the inside bar - the cap still attached, then unscrewed the rest from the cap. Is there a hex bolt welded to the inside of that cap that I need to use to make it hold the eye-bolt in place? If not, how do you get the cap and eye-bolt tightened together? You need a Hook Spanner to tighten it. |
dawg |
Mar 25 2013, 03:30 PM
Porsche had a special jig that the racks fit in. Eye bolts have to be canted at about 8 (?) degrees. If the eye bolt is NOT at the proper angle, the steering rack will bind. Yes, the metal cap has to be in place to act as a spacer. The eye-bolt is already canted. The angle points toward the rear of the car. What I don't understand is what holds the eye-bolt in that position. The cap acting as a lock nut? Yes. Didn't you loosen it to remove the eyebolt? Not really.... I removed the eye-bolt with the steering still mounted on the car. I just took it off untill it came free of the inside bar - the cap still attached, then unscrewed the rest from the cap. Is there a hex bolt welded to the inside of that cap that I need to use to make it hold the eye-bolt in place? If not, how do you get the cap and eye-bolt tightened together? You need a Hook Spanner to tighten it. thanks! |
Lo-Fi Version | Time is now: 14th January 2025 - 06:44 PM |
