76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
As revealed earlier, I don't know (IMG:style_emoticons/default/stromberg.gif) about suspension. I did know enough to listen to the pros and have taken Eric's set up advice. (guess who has new Bilsteins coming (IMG:style_emoticons/default/biggrin.gif) ) My question is this; how do I identify what I currently have? Is this done by the number of coils? Is it stamped somewhere? Color coded? Here is a shot of mine. And...what does 100,120,140lb represent? What happens at a given value? TIA, kent
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The rate is "pounds of force per inch of deflection". That suggests how you would test it:
Weights to put on the end of the spring, and a ruler to measure how far it compresses. Take measurements with different amounts of weight. lbs of weight / inches of compression == lb/in spring rate. ...Or you take them to a shop that has a spring tester, which does the same sort of thing with much more precision. --DD |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Weights to put on the end of the spring, and a ruler to measure how far it compresses. Take measurements with different amounts of weight. lbs of weight / inches of compression == lb/in spring rate. (IMG:style_emoticons/default/agree.gif) Measure spring length at rest. Put a known weight on top of the spring. Measure difference in length. Plug the known weight (in lbs) and the difference in length (in inch) into the formula above, normalize to 1 inch and voila! (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:06 PM |
