Minimum Rotor Thickness |
yeahmag |
Oct 18 2011, 06:11 PM
Advanced Member Group: Members Posts: 2,443 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
My Chilton's (or whatever book it is) states .394" as the minimum thickness for the front rotors. Is that the correct value? Both sets I have (used) are measuring at roughly .345".
-Aaron |
jcd914 |
Oct 19 2011, 06:08 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
You are asking about Front rotors, correct?
0.394 & 0.374 are both correct but different specs. They can be machined to 0.394 they can be worn down to 0.374 Factory specs (mm): (I did the mm to in conversions) Thickness New: 11mm +0.05mm -0.15mm (0.4331in +0.002in -.006in) Min. Thickness after machining 10.0mm (0.394in) Wear Limit 9.5mm (0.374in) Jim |
matt5596 |
Mar 25 2013, 08:27 PM
Member Group: Members Posts: 102 Joined: 28-September 11 From: Norris, TN Member No.: 13,619 Region Association: South East States |
You are asking about Front rotors, correct? 0.394 & 0.374 are both correct but different specs. They can be machined to 0.394 they can be worn down to 0.374 Factory specs (mm): (I did the mm to in conversions) Thickness New: 11mm +0.05mm -0.15mm (0.4331in +0.002in -.006in) Min. Thickness after machining 10.0mm (0.394in) Wear Limit 9.5mm (0.374in) Jim What about rear rotors? |
Lo-Fi Version | Time is now: 28th December 2024 - 12:19 AM |
