Minimum Rotor Thickness |
yeahmag |
Oct 18 2011, 06:11 PM
Advanced Member Group: Members Posts: 2,443 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
My Chilton's (or whatever book it is) states .394" as the minimum thickness for the front rotors. Is that the correct value? Both sets I have (used) are measuring at roughly .345".
-Aaron |
jcd914 |
Oct 19 2011, 06:08 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
You are asking about Front rotors, correct?
0.394 & 0.374 are both correct but different specs. They can be machined to 0.394 they can be worn down to 0.374 Factory specs (mm): (I did the mm to in conversions) Thickness New: 11mm +0.05mm -0.15mm (0.4331in +0.002in -.006in) Min. Thickness after machining 10.0mm (0.394in) Wear Limit 9.5mm (0.374in) Jim |
matt5596 |
Mar 25 2013, 08:27 PM
Member Group: Members Posts: 102 Joined: 28-September 11 From: Norris, TN Member No.: 13,619 Region Association: South East States |
You are asking about Front rotors, correct? 0.394 & 0.374 are both correct but different specs. They can be machined to 0.394 they can be worn down to 0.374 Factory specs (mm): (I did the mm to in conversions) Thickness New: 11mm +0.05mm -0.15mm (0.4331in +0.002in -.006in) Min. Thickness after machining 10.0mm (0.394in) Wear Limit 9.5mm (0.374in) Jim What about rear rotors? |
jcd914 |
Mar 26 2013, 12:27 AM
You are asking about Front rotors, correct? 0.394 & 0.374 are both correct but different specs. They can be machined to 0.394 they can be worn down to 0.374 Factory specs (mm): (I did the mm to in conversions) Thickness New: 11mm +0.05mm -0.15mm (0.4331in +0.002in -.006in) Min. Thickness after machining 10.0mm (0.394in) Wear Limit 9.5mm (0.374in) Jim What about rear rotors? These specs are not from a factory manual (don't know where my factory spec book is). These are from a Peter R.D. Russek VW/Porsche 914/4 Repair Guide, I found on-line a couple years ago. It is a nice little manual to have, little as in it fit in the glove box and can be with your 914 at all times. All the info looks like it came from Porsche. Thickness New: 9.5mm (0.374in) Min. Thickness after machining 8.9mm (0.350in) Variation in thickness 0.2mm(0.008in) No wear limit is listed in this manual Jim |
Lo-Fi Version | Time is now: 28th December 2024 - 01:03 AM |
