ww914 |
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California ![]() |
Will they work? Anybody running them?
ottox914 |
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest ![]() ![]() |
Back when I had money for tires, I ran A4's on stock 5.5 fuchs 4 bolt rims. I had no rubbing issues, did not need to roll or cut anything, but clearances were close. I switched to some 7" rims. I had to roll and cut a tiny bit on the back, nothing to the front. As the offset was not perfect, I had some spacers made. The tires and car were transformed. It was like a new and more awesome set of tires. The wider rims allowed the tires to perform to their full potential. Run on the 5.5's if you have no other options. Find a way to get those skins on to some 7's for best results.
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Back when I had money for tires, I ran A4's on stock 5.5 fuchs 4 bolt rims. I had no rubbing issues, did not need to roll or cut anything, but clearances were close. I switched to some 7" rims. I had to roll and cut a tiny bit on the back, nothing to the front. As the offset was not perfect, I had some spacers made. The tires and car were transformed. It was like a new and more awesome set of tires. The wider rims allowed the tires to perform to their full potential. Run on the 5.5's if you have no other options. Find a way to get those skins on to some 7's for best results. +1 (IMG:style_emoticons/default/biggrin.gif) Cookie cutters are cheap! |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
and heavy. (IMG:style_emoticons/default/dry.gif) I have a set of 4 lug centers available for 3pc Keizer wheels. |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
and heavy. (IMG:style_emoticons/default/dry.gif) I have a set of 4 lug centers available for 3pc Keizer wheels. These things are relative. Cookie cutters are pretty similar to Fuchs 5-lug in weight, which I don't think is a lot. The heavy wheels are the new fake mini-lites and the revolutions. Also 16" boxster wheels. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:38 AM |
