ww914 |
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California ![]() |
Today at the track, with my new Hoosier A6's, I was lifting the inside front tire. I had installed 180 lb springs, took off the rear sway bar and tightened up the front 19mm Tarrett just a little. Everyone at the track told me that I needed beefier springs in the back. Well, I have 220 lbs springs, shall I try them? Shall I leave the sway bar off? Should I soften or tighten the front sway bar? Oh, I am running 205/15 on 5.5 rims. I am looking at 7" rims to get the patch better. Any other recommendations?
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Which end of the car would you like to have more grip?
ww914 |
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Which end of the car would you like to have more grip? The rear, I guess, since right now there is only one wheel on the ground in the front. So was the car loose in front, i.e., understeering? Or loose in the back, i.e., oversteering? |
ww914 |
Which end of the car would you like to have more grip? The rear, I guess, since right now there is only one wheel on the ground in the front. So was the car loose in front, i.e., understeering? Or loose in the back, i.e., oversteering? It seemed pretty balanced to me. I felt like I was in control of the car, not the car of me. It just didn't seem like I was driving smooth, but maybe that's me. With more seat time, I guess I will figure it out. |
Woody |
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region ![]() |
Which end of the car would you like to have more grip? The rear, I guess, since right now there is only one wheel on the ground in the front. So was the car loose in front, i.e., understeering? Or loose in the back, i.e., oversteering? It seemed pretty balanced to me. I felt like I was in control of the car, not the car of me. It just didn't seem like I was driving smooth, but maybe that's me. With more seat time, I guess I will figure it out. Its an addiction. There is no substitute for seat time. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:28 AM |
