ww914 |
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California ![]() |
Today at the track, with my new Hoosier A6's, I was lifting the inside front tire. I had installed 180 lb springs, took off the rear sway bar and tightened up the front 19mm Tarrett just a little. Everyone at the track told me that I needed beefier springs in the back. Well, I have 220 lbs springs, shall I try them? Shall I leave the sway bar off? Should I soften or tighten the front sway bar? Oh, I am running 205/15 on 5.5 rims. I am looking at 7" rims to get the patch better. Any other recommendations?
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Think about the wheel lifting this way - If you lift the front tire, did the front end get loose? If not, then you had enough grip with only 1 tire on the ground.
I think that when I AX I'm trying too hard to go fast. You may go faster by working on better entry/exit lines, rather than 'going faster'. That's where I am. Trekkor's last AX school at Infineon had a tight 180 corner and I just couldn't get around it without massive understeer. I tried to force oversteer, I tried to just plow through, but at the end of the day I realized that I simply needed to go slower. I never did get to put that in practice, so next time out I'll be working on that. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:26 AM |
