ww914 |
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California ![]() |
Will they work? Anybody running them?
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
15 X 7 Fuch are 11 lbs on my bathroom scale. Cookies are 12 lbs.
Both are some of the lightest production wheels one can buy. Trick 3 piece wheels can knock a couple 3 lbs off that.......bring money if you need that extra half tenth second. |
ww914 |
15 X 7 Fuch are 11 lbs on my bathroom scale. Cookies are 12 lbs. Both are some of the lightest production wheels one can buy. Trick 3 piece wheels can knock a couple 3 lbs off that.......bring money if you need that extra half tenth second. Well, the Revolutions came in and I already have the Hoosiers mounted. They sure fit on the rim better than the 5.5s. I didn't notice it before but the Hoosiers on the 5.5s were hitting the inner fender well pretty hard, so I have ordered 1/4 in spacers and longer lug bolts. Had to roll the outer fenders a little more. When I get everything back together, I may have to work on those fenders again. I got my rear coilovers with 225 lb springs and will install them tomorrow. I have the front suspension apart waiting for new polybronze bushings. The PO installed 22mm torsion bars at some point, so I will leave that part alone. I will play with the camber a little. I have an appointment for cornerbalancing on the 9th. So, since my last AX, the only things I will have changed is wider wheels, the rear spring weight, a little more neg camber in the front, new suspension bushings and a corner balance. That shouldn't be too much of a change, do you think? By the way, the Revolutions weigh 20 lbs, which is 6 lbs more than the Fuchs. I can sure see were a guy can dump a ton of money into this stuff, just like JP and Chris alluded to. Oh well, it sure is fun! |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
That shouldn't be too much of a change, do you think? (IMG:style_emoticons/default/biggrin.gif) Sounds like enough of a change. I wouldn't do anything else for a while except maybe adjust the front sway bar, and/or tire pressures between events. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:17 AM |
