tadink |
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California ![]() |
Doing some ax and am looking for more stiction
Am running contiprocontacts now Thoughts? TD ps, sorry for the auto correct on the original post - was doing it from my cell phone td |
Borderline |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California ![]() |
Yeah, I spent some time converting over to 13" wheels and in the process removed about 80# of unsprung wt. The main reason for the 13" wheels was to be able to run the Hoosier R25B compound slicks. I was a little disappointed last year as I was doing development on used tires. For this year I bought new tires and so far am very happy!
jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
Yeah, I spent some time converting over to 13" wheels and in the process removed about 80# of unsprung wt. The main reason for the 13" wheels was to be able to run the Hoosier R25B compound slicks. I was a little disappointed last year as I was doing development on used tires. For this year I bought new tires and so far am very happy! Bill, I'd like to know what was involved in your 13" conversion. Did you retain the stock rotors, and if not, what did you use? -Josh |
Borderline |
Yeah, I spent some time converting over to 13" wheels and in the process removed about 80# of unsprung wt. The main reason for the 13" wheels was to be able to run the Hoosier R25B compound slicks. I was a little disappointed last year as I was doing development on used tires. For this year I bought new tires and so far am very happy! Bill, I'd like to know what was involved in your 13" conversion. Did you retain the stock rotors, and if not, what did you use? -Josh It was a lot of work. I machined the rotors down to 10" diameter and then did some custom mount brackets for the light wt Wilwood calipers. I had custom wheels made by "Real Racing Wheels" with the 4 bolt 914 pattern. Gee that makes it sound so easy. The wheels weigh about 10 lbs each and so do the Hoosier bias ply slicks. The Wilwood calipers weigh about 2 lbs!!! By the time the rotors had been turned down and thinned a little the overall wt loss was about 20 lbs per corner. Now, with the smaller wheels I start the AX in 2nd gear and then go to 3rd (flipped 5th). It works great and I don't have to flair the fenders..........much (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 12:27 AM |
